Old 04-09-2015, 02:11 PM   #1
pink71c10
custom instrument panel
This is someones dash on this forum im new to to this would like to know how they made it what guages and what type of guages im wanting to do something similar out of wood and were did you get the turn signal indicater
pink71c10 is offline   Reply With Quote
Old 04-09-2015, 10:17 PM   #2
pink71c10
Re: custom instrument panel
Any one have any ideas any help would b appreciated
Old 04-10-2015, 01:25 AM   #3
Ratpick
I dunno about this one in particular but it's some mismatched Autometer gauges. (Different colours) I don't know about that signal indicator, it is kinda cool. Pick some wood you like, and make a panel. Then order up a set of gauges you like (I suggest vdo, good stuff) then cut holes and do wiring. The factory cluster can be made to work and can have tachometer added to center.
Ratpick is offline   Reply With Quote
Old 04-10-2015, 06:14 AM   #4
Bigdav160
Bigdav160's Avatar
Check out New Vintage USA
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-10-2015, 07:38 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: custom instrument panel
I wonder why they used 3 differant color gauges?
I like the speed hut stuff myself.
www.speedhut.com
GPS speedo with no calibration just install it and drive.
Mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-10-2015, 11:08 AM   #6
pink71c10
www.speedhut.com
Mine.
Those are nice ill look at those wonder why there is six little guages
Old 04-10-2015, 12:34 PM   #7
Bigdav160
Bigdav160's Avatar
I have a lot of gauges
Speedo, Tach, A/F ratio, trans temp, vacuum, water temp, oil pressure, fuel level, volt meter and a clock.
Did you check my link above? It has those indicators
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 04-10-2015, 01:03 PM   #8
pink71c10
Not yet but after i get off work im going to thanks for the link yours are nice to
Old 04-10-2015, 03:55 PM   #9
Andy4639
Old member
Andy4639's Avatar
Talking Re: custom instrument panel
With the 6.0 and 4L80 e transmission I have the scan gauge 2 also that has water temp, trans temp, volts, mas air temp, closed loop/open loop and any number of other gauges you decide which ones you want.
Plug into the computer port and reads straight off the ECU.
Old 04-10-2015, 05:52 PM   #10
Fasteddieb
I would LOVE to see the wiring behind all of that. I have Auto Meter gauges the PO installed but the wiring is a rat's next. I'd like to wire everything into a single connector. Any photos, links, diagrams, hieroglyphics, etc, would be appreciated!
Fasteddieb is offline   Reply With Quote
