04-09-2015, 03:47 PM | #1 |
LS swap temp sensor ???? 90 suburban gauge cluster
Hey guys my question is for the guys running the 90 electronic suburban gauge cluster are you guys running the temp sensor for the electronic cluster from the suburban or what are you using. I'm running the 90 gauge cluster and want to make sure i order the right sensor to work for my temp gauge i'm using PSI Conversion.com harness have everything else working but the temp gauge i understand I might have to tap the passenger side head to make work any help would be great thanks
04-09-2015, 04:57 PM | #2 |
Re: LS swap temp sensor ???? 90 suburban gauge cluster
I'll be doing this on my swap, turning down and tapping the stock sensor to fit the Passenger side head.
http://www.impalassforum.com/vBullet...d.php?t=273845 |
05-17-2015, 07:34 PM | #3 |
There is no need to drill, tap, glue, weld or any of that stuff for the temp sender, the 98-02 firebird temp sender has three wires, use the third wire for the gauge and yes the ohmage matches, I've done a bunch of these and is a lot simpler
Dan G Lift it, fat chicks cant jump! 83 Chevy shortbed 4x4: 6.0 ls powered 97 Chevy 3/4 ton ex cab 454: work horse 00 Chevy camaro: daily driver 83 Chevy 3/4 ton: dads old rig |
05-17-2015, 08:32 PM | #4 |
Post Whore
I used the psi harness on mine to.it has the connector that hooks to the sending unit in the head on drivers side.this is the sensor the ecm reads to turn on electric fans and light up the check engine lights. I simply drilled and tapped passenger head and installed another sensor for the dash gauge.
05-21-2015, 09:02 PM | #5 |
BMW & ASE Master Certified
I simply used the autometer coolant gauge sender with adapter. no drilling, no tapping. I remember reading "if you don't want to spend 10 bucks..lol... on the adapter, just tap the allen plug you remove on the passenger head for the sender. Further reading revealed when tightening, modified plug broke and threads were stuck in head.
-clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
