Old 04-09-2015, 05:03 PM   #1
butchp
Steering Column
I have a 76 Camaro sub on my stock frame it is mounted to the bottom of my frame. I plan to use the steering shaft from the camaro. What length steering column are you guys using.
butchp is offline   Reply With Quote
Old 04-09-2015, 05:49 PM   #2
Advanced Design
Advanced Design's Avatar
Re: Steering Column
That could vary. May be most accurate to measure for yours.
Here is a guide-
http://www.ididitinc.com/pdf/HowToMe...ringColumn.pdf
Hope that helps!
Advanced Design is offline   Reply With Quote
Old 04-09-2015, 06:57 PM   #3
OrrieG
OrrieG's Avatar
Re: Steering Column
82 Eldorado. Shaft is shorter than standard so it does not extend as much past the firewall.
OrrieG is offline   Reply With Quote
