04-09-2015, 05:10 PM | #1 |
Towing with our trucks
Was wondering if anyone has been towing things like a small travel trailer with the C-10's. I have a 283 which I know is not a torque monster but it does have a RV cam with power pack heads and two barrel carb, with 3:08 gears and was wondering what everyone would think about it being able to tow say a 3000 lbs trailer? It is a 3 on the tree with a 10.5 new clutch.
Thanks for any input Ronw435 |
04-09-2015, 05:23 PM | #2 |
It's Better With Nitro
Re: Towing with our trucks
For me, towing capability means more about the braking, cooling and highway stability. I'm sure your small block can pull the trailer, but is the rest of the truck up to doing it and stopping safely?
04-09-2015, 06:02 PM | #3 |
Very true, at the least probably disc brakes with booster would be a must. And some sway bars?
Thanks for the reply. |
04-09-2015, 08:30 PM | #4 |
...and, don't forget the transmission and engine cooling. Plus, the properly rated tires. I used to pull our horse trailer (~6K pounds loaded) with my C10.
04-09-2015, 09:09 PM | #5 |
Post Whore
3.08.1 is a bit tall for a 283, but it'll tow it. Long as like mentioned your stay cool and yer brakes work. ol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-09-2015, 09:27 PM | #6 |
trailer brakes should be considered and 373 gear as well
04-09-2015, 11:23 PM | #7 |
If you mean 3,000 lbs. total gross that's not much of a trailer. My 2.5L 5 cyl. Volvo wagon has done that on 1500 mile, 65mph highway trips more than 6 times in the last 2 yrs. It's rated for 3500 lbs.
The cooling system needs to be up to snuff and brakes might be the only concern. Usually trailer brakes are found on heavier trailers than that. |
04-10-2015, 01:15 AM | #8 |
meowMEOWmeowMEOW
I can tow anything up two a car trailer pretty easily, but at that point my super short wheelbase and lack of trailer-brake control becomes sketchy. A travel trailer, or a car on a wheel-dolly isn't bad.
Power wise I can pull a G20 out of a ditch. *my drivetrain, braking, and suspension are a little different tho
04-10-2015, 07:35 AM | #9 |
Shouldn't be a problem.
The Chevelle plus the trailer here is about 4500 lbs. 24' Haulmark enclosed trailer is beyond what I would do again. Truck is a 4.3L V6, manual trans w overdrive, 3.73 axle. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-10-2015, 07:44 AM | #10 |
Yeah what were looking for is a small travel trailer, maybe a retro about 17ft, to take camping. We are currently camping in a tent and encountered a bear that came within about 10 ft of the tent and would like a little bit more between us besides just some fabric....lol. Would never consider pulling a large trailer with it.
04-10-2015, 08:38 AM | #11 |
.44 be cheaper and bear is pretty good eating.
I don't think you'd have any issues with a small travel trailer. Pulled a 61 falcon loaded with parts all the way back from Billings, Montana to Fayetteville, NC on a big Uhaul car trailer few years back with no issues. And that was with the 230 installed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-10-2015, 09:52 AM | #12 | |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-11-2015, 08:31 AM | #13 |
Check The Champ, Demonstrator
Trailer brakes are a huge asset, especially when it starts to get away from you. That's why on the big transport trucks are equipped with a spiker, to activate the trailer brakes only, to straighten everything out.
Nostalgia Link http://67-72chevytrucks.com/vboard/s...d.php?t=568667
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
04-11-2015, 03:37 PM | #14 |
Well most of the trailers we are going to be looking at will be16-19ft. I doubt that they will have trailer brakes. Since I am retired we dont have to run 75-80 down the interstate. Look to run around 60-65 conditions allowing. Aerotruk the trailer you have there is about what we are looking for. Is that an Airstream?
04-11-2015, 04:54 PM | #15 |
1974 Airstream. Frame rusted out on it so I shortened it. Has electric brakes though, on the new axle. Be careful when purchasing an Airstream of this era....
What it was ....and closer to completion of modifications.
04-11-2015, 05:01 PM | #16 |
ANy help with braking is a plus. No matter how big the trailer is. My TT is 15' and it has trailer brakes.
04-11-2015, 09:32 PM | #17 |
if a trailer is 3000 lbs that's dry, water waste tanks food ect. now its 4000 lbs trailer brakes are on most travel trailers and they should engage first
04-12-2015, 12:37 AM | #18 |
Added elec brakes and a controller, towed like a dream. Was assembling semi trailer glad hands and some firestones to bag the trailer then sold it. Didnt even know it was back there with the V8 and 4 wheel disc. Also towed it behind the 250 700r4 combo in the 50 burb, also trailer brakes. Did a 2800 mile trip last summer.
GOD BLESS AMERICA! |
04-12-2015, 08:43 AM | #19 |
Sweet Burb. That is what we are looking for, so you say they do come with brakes?
Thanks for posting. |
04-12-2015, 10:18 AM | #20 | |
Chevy addict
04-13-2015, 03:50 AM | #21 |
Trucks are meant for towing... other trucks!
I agree that good brakes are key. 3,000# trailer isn't too much, but trailer brakes are always nice too. With 3.08 gears in the rear slow and steady will be the name of the game, but I would think it should be fine.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
04-13-2015, 05:36 PM | #22 |
You can buy an axle that is equipped with braked and install it. 4 u bolts and run the wire to the tongue. Easy
04-13-2015, 11:39 PM | #23 | |
1966 Crew Cab & 4X4 Fanatic
04-14-2015, 06:14 PM | #24 |
Some really nice stuff you guys have on here...lot of fun to look at!
I think the 3.08 is going to be a bit of a stretch on some of the grades, you may need to shift up a bit more often then normal. I agree...get something with trailer breaks. They are tons of units out there with them and the cost of an accident without em makes them imperative! Best, Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
04-14-2015, 06:46 PM | #25 |
you can put elects brake on anything.... probably the easiest transformation of any on a trailer. Just find what you like and go get a brake kit for it if it doesnt have them already.
My Build: 57 Chevy Pro-Street |
