Old 04-09-2015, 08:40 PM   #1
Ghernandez66
Ghernandez66's Avatar
Question Body mounts question
So I'm about to start putting the body back onto my 66 frame and realized that I have the cab mounts with bolts and all but I don't have any other bolts for the body.
Does any one know if I can just get some from the hardware store or do I have to purchase the ones online sold as kits?
I know I'm missing the ones for the front end to the frame and to the cab also the bed 8 bolts.
Hope someone can help.
thanks in advance..
Ghernandez66 is offline   Reply With Quote
Old 04-10-2015, 06:35 AM   #2
PGSigns
PGSigns's Avatar
Re: Body mounts question
With not having anything to go off off you may be better off getting the kits. The kits will have the correct bolts and other hardware you need also.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-10-2015, 09:31 AM   #3
1963c-10
1963c-10's Avatar
The radiator support requires a kit that has thick rubber and metal washers. As for the sheetmetal, you can purchase the bolts locally, but as said above, the kits do make it much easier since they come with all the hardware.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
