04-09-2015, 10:35 PM | #1 |
Bed Wood (Almost) Removed!
After finding a cro-bar and prying the old bed wood out, I'm almost ready to remove the chrome (Or what is now rust) strips!
I'm from the country, and I like it that way! |
04-09-2015, 11:42 PM | #2 |
Re: Bed Wood (Almost) Removed!
OEM was NOT chrome just black painted steel
04-10-2015, 12:31 AM | #3 |
Easier way would have been to unbolt the strips 1st.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-10-2015, 12:36 AM | #4 |
Might be less work to tighten them so they shear off.
04-10-2015, 04:37 AM | #5 |
if you have the space and a few extra hands, take the 8 bolts that hold the whole bed and take the bed off, then stand it up right and remove the bolts, or cus, get dirt and debris in ur eyes and wish you had like i did when i removed my wooden bed strips still on the truck!!!
04-10-2015, 09:47 AM | #6 |
Moderator
Don't bother with wrenches, just use a cut off wheel on a grinder. You'll have it done in twenty minutes. For sure, if you're going to remove the bed anyways, take it off, stand it up. Really easy to work that way. At least put it on a couple sawhorses or four stands.
04-10-2015, 10:24 AM | #7 |
Most the bed strips look salvageable to me. I'd use a grinder as jayoldschool said or a reciprocating saw and reinstall with new bolts.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-10-2015, 01:47 PM | #8 |
Moderator
04-10-2015, 03:40 PM | #9 |
I had to take mine off and stand it up like was said before. I also took the wheel wells out and replaced those bolts while I was at it.
66 shorty |
