Old 04-09-2015, 10:39 PM   #1
simplepeddler
Entire Brake hardware kit?
Any leads to an entire hardware kit?
pulled the tires of the passenger side of the latest buy and there is nothing there at all, just the rotor and drum......wierd.......guess the PO was going to rebuild them but lost the hardware........
simplepeddler is offline   Reply With Quote
Old 04-09-2015, 10:43 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Entire Brake hardware kit?
Rotor AND drum?
I got a complete drum brake hardware kit from the local auto parts store for my 1972 GMC. Wasn't very expensive. My 72 only has drums in the rear.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-09-2015, 10:47 PM   #3
simplepeddler
yes ....disc on the front.....drum on back 3/4 ton.........
that makes sense.......guess it just rattled me that it was ALL gone
Old 04-09-2015, 10:47 PM   #4
Ratpick
Yeah if it's drum brakes the parts store hardware kit and shoes should pretty much cover it. Unless wheel cylinders or park-brake parts are missing. Then it's junkyard time.
Ratpick is offline   Reply With Quote
Old 04-09-2015, 10:49 PM   #5
Ratpick
Oh ok, new slide pins and calipers should be available. But it might turn into a "wrong-part-exchange-hoedown"
Old 04-09-2015, 10:51 PM   #6
Ratpick
I once had a customer bring in an old Maverick that wasn't stopping well. It had drum on one side up front and disc on the other, neither working properly. That rattled me a bit
Old 04-10-2015, 12:31 AM   #7
GASoline71
GASoline71's Avatar
You said 3/4 ton. What rear end? If it's an Eaton... parts might be a little scarce.
Gary
Old 04-10-2015, 06:05 PM   #8
simplepeddler
Gary
I will have to learn somthing here........have idea!
Old 04-11-2015, 08:48 AM   #9
bill3rail
bill3rail's Avatar
You've never heard of Passenger side Drum/Driver side Disc brakes?
It was all the rage in the 70's!
bill3rail is offline   Reply With Quote
Old 04-11-2015, 08:51 AM   #10
COBob'70 K-10
That's funny right there!
COBob'70 K-10 is offline   Reply With Quote
