Old 04-10-2015, 03:00 AM   #1
Mistercates
Mistercates's Avatar
66 with 86 cross member what do i buy
I just picked up an 86 cross member and want to go ahead and lower it while im putting it on. What is the lowest you can go without notching? I have heard 4 front 5 back. Also do i just need to buy drop spindles and springs for the cross member since it already has disc brakes? I have read the other forums but just wanted to make sure before I purchased anything. Also will i need an adjustable track bar for the back? What about sway bar for the front?
Thanks!
______________________________________________
RON
66 short fleet cc bbw
factory 283 3spd
Mistercates is offline   Reply With Quote
Old 04-10-2015, 06:32 AM   #2
PGSigns
PGSigns's Avatar
Re: 66 with 86 cross member what do i buy
I have that setup in my 66. I have 2" springs in the front and 2 1/2" drop spindles. I used the aftermarket 6 lug rotors. Summit has the best price on them. In the rear I have 4" springs and a 1" block with the ECE super track bar and ECE shock re-locators. I am running the Belltech street performance shocks. I used the power steering adapter and brake booster bracket from Captianfab here on the board. When I did the swap on mine I did not swap the crossmember just everything else. I also did the caster mod from the make it handle thread. I got all the ball joints and other front end rebuild parts from Amazon and got some really good deals.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-10-2015, 11:47 AM   #3
Lowl!f3
Lowl!f3's Avatar
On the front get drop spindles from summit
CLP-CP4S4Spindles, Ductile Iron, 2.5 in. Drop, Chevy, GMC, Pickup, Pair (Mfr. #: CP4S4)
And run a 1 or 2 inch drop spring.
Note you will have to saw off the bumpstop and bracket so you dont bottom out as quickly.
Possibly install a single stud bumstop if you like to stop metal to metal bottoming out.
If you dont put a drop spring. You can run 3" drop spindles.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 04-19-2015, 01:23 PM   #4
Mistercates
So will any of the spindles fit the 86 crossmember especially the ball joints? Just wanted to get all this figured out before i buy unecessary stuff
RON
factory 283 3spd
Old 04-19-2015, 03:24 PM   #5
GVDobler
GVDobler's Avatar
Ron
Check with your supplier, but you need spindles for an '86 since that's what you have. I'm sure the same part number covers multiple years, but start with asking for a set that fits an '86. I have a complete '87 not installed yet, and everything that I order will be for an '87.
Note:They are metric after about '81 or so (not sure of year)
Jon
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
