Old 04-10-2015, 04:46 AM   #1
cblock
cblock's Avatar
71 c10 4.3
whats up everibody, I just got a1971 c10 longbed with a 350 eng /350 tranny combo, and I'm seriously considering putting a 4.3 v6 with an automatic overdrive transmission from a mid 90's s10 blazer, i use to have a 1978 blazer 4x4 and it was a gas guzzler. I've owned several 90's chevy v8 and they're ok, but I want a truck that I can drive everyday. any advice or prior experiences will be greatly appreaciated.thanks.
cblock is offline   Reply With Quote
Old 04-10-2015, 07:13 AM   #2
hugger6933
Re: 71 c10 4.3
Go back with the 350 and the overdrive. I am a s-10 man or used to be I built tons of them over the years and owned one of every year model through the whole run of them[I built a lot of S-10's] While the 4.3 is a good motor its basic problem in the full sized truck [and the S-10] was it was underpowered. I have built in younger days quite a few V-8 S-10's and if the motor was stock it would always get better mileage than the V-6 counterpart because it didn't have to work as hard to do the job. That is the main reason I say use a 350 with similar equipment[like a TBI] and the overdrive trans. That is where the main improvement in gas mileage will be found. Jim
hugger6933 is offline   Reply With Quote
Old 04-10-2015, 07:53 AM   #3
Re: 71 c10 4.3
Do yourself a favor and find a good 307. Slap a small 4bbl on and get even better mileage.
I see this was your first post, welcome to the site!
Old 04-10-2015, 09:11 AM   #4
70cst
70cst's Avatar
Re: 71 c10 4.3
Hey cblock ...
to the forums and from Ohio.
I would luv to see some pics of your ride.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-10-2015, 10:10 AM   #5
Longhorn 70
Longhorn 70's Avatar
Re: 71 c10 4.3
Welcome to the board cblock !
I agree with Jim. I have owned good running 4.3s and while they were super reliable, they sucked wind. A good running 350 will get better mileage in heavier square vehicles. In my opinion, the reason our trucks get poor fuel economy is due to their frontal area and gear ratios.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 04-10-2015, 02:20 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: 71 c10 4.3
Agreed with all above. 4.3 is not enough motor for a full size truck and they don't get good mpg anyway.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-10-2015, 09:47 PM   #7
rotten67
Re: 71 c10 4.3
I have a 96 c1500 with a 4.3 and a 5 speed gets 15 mpg in town. seems to have decent power.
rotten67 is offline   Reply With Quote
Old 04-11-2015, 12:30 AM   #8
c10-72 II
Active Member
c10-72 II's Avatar
Re: 71 c10 4.3
I was thinking the same thing but adding a turbo. Like the old school syclones and typhoons.
c10-72 II is offline   Reply With Quote
Old 04-11-2015, 05:37 AM   #9
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: 71 c10 4.3
I too have a '96 4.3. It has a roller cam, dual cats, port injection, and the Vortec heads. I was never impressed with the earlier 4.3s but this one does pretty good on the power/mileage thing.
Use the search function. There are several other 4.3 threads on this site where this has been talked about extensively.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
