4BT v Hercules diesel
I am very interested in building a diesel in a couple years as a side project, and have done a bit of research.
The 4BT is very heavy, and the most common of the smaller diesels with the sae housing. Also it is capable of big HP/tq with a large aftermarket. The Hercules is much lighter just under a typical big block, and has the sae housing too. At the power level I would build it up too it has very few relibilty issues as I just want it to get out of its own way to make merging easy enough or about 8 seconds to 60. Both are mechanical which makes swaps easy, and are compact enough with the rear sump. So where is a good resource for used engines of this nature besides ebay in the LA area? Also is there other engines that I should consider or look at? Will these engines work on B20 or B50 in the mid west. |
![]() Join Date: Mar 2011
Re: 4BT v Hercules diesel
I do not believe a Hercules is much lighter than a 4bt.
My 4bt weighted in at 720 lbs about what a big block weights, and less than the GMC v6 that came out of my 4x4 frame.
63 k20 with cummins 4bt, owned sence 1982 |
The forums I read said it did, and there was quite a few that did. So that is all I know.
Just intrigued by diesel as of late considering it is cheaper then 87 right now which is weird in my area. |
I found this on Dieselstop.com: (This Step van is a Grumman Olson on a Ford E-350 chassis. It is powered by Hercules 3.7l Turbo Diesel engine. It has a 4 speed T-19 transmission. This engine provides terrific fuel economy 14-17 around town 17-20 on the highway, depending on load and driving habits" (Excerpt from an eBay listing of a Grumman step van).
I looked up this motor; found the HP was 130....torque I could not find. weight: 619 lbs.) 100 lbs is not a lot. If you are doing it for savings it will take a long time to recoup cost and if you count your time as worth anything it may never break even. But I have had my diesel conversion for 15 years and have no plans of parting with it ever.
It would not be about recouping cost. Although my finished truck would be worth more then what I have into it.
It would be about having a truck I wanted. Personally I just don't feel right in the new trucks. Something about them does not touch my soul. My K20 would honestly look better with a good coat of fire, but I love driving it. I thought about the 4bt for it in a few years, but it would require more mods then what to do just for it cruise faster then 60. Where as a 2wd the options are easier. |
It doesn't require a lot of mods, just proper gearing and an overdrive trans to cruise at 70 ish.
6>8 Plugless........
![]() Join Date: Sep 2007
Sorry, I can't offer any info on the Hercules. I haven't been around any of them.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
| Bookmarks |
