Old 04-10-2015, 03:23 PM   #1
rs74
rs74's Avatar
Squeaking noise under truck.
I had this squeaking start yesterday. First I thought it might have been front end related. I jacked up the front end and rotated the wheels and heard nothing. That might mean nothing since there was no weight on the wheels but that is what I have done. I got under the truck today and can spin the front drive shaft both ways freely. I noticed what seemed like the sound I am hearing coming from the front out put of the transfercase. I greased the ujoints just to make sure and no difference. Is there a press in bearing right there or what could be making that noise. Should the driveshaft be spinning while driving since I can spin by hand when not running?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-11-2015, 05:40 PM   #2
rs74
rs74's Avatar
Re: Squeaking noise under truck.
Is there a bearing behind the front output shaft seal that can be changed easily?
Roy
1987 R10 shortie
Old 04-11-2015, 10:23 PM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
you need to grease the driveshaft yolk. I believe you have to use atf since yours is 4wd. I just did this on my 2wd and it quit making noise and clunking
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 04-12-2015, 08:42 PM   #4
rs74
rs74's Avatar
Found it. The center piece of the double u joint on the front driveshaft was dry. It is like a ball and socket and found the grease zerk was broke. I was able to get some grease in there until I can get time to tear it apart.
Roy
1987 R10 shortie
