Old 04-10-2015, 09:07 PM   #1
fatblockvelle
fatblockvelle's Avatar
1971 blazer... factory cruise???
can someone fill me in... i just got a blazer from out west.... looks to be factory... rare??? dealer installed??? can post pictures.
Thanks!!! jesse!
1970 chevelle
1971 blazer
1972 c20 custom camper
1931 ford A coupe.
fatblockvelle is offline   Reply With Quote
Old 04-10-2015, 09:47 PM   #2
jaros44sr
jaros44sr's Avatar
Re: 1971 blazer... factory cruise???
Thanks!!! jesse!
picks would help, I ve got one to compare to. Not sure, but I believe they were dealer installed. Not overly rare, but pricey, if they work
If it was listed on your SPID, I would say it was factory installed
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-10-2015, 09:51 PM   #3
fatblockvelle
I unplugged it to get a better photo
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 04-10-2015, 09:56 PM   #4
Blazerowner
Blazerowner's Avatar
Probably dealer installed they never came factory. I tossed one years ago thinking it was some crap the prior owner stuck on. Found out later it was worth some money. Never throw anything away was my lesson.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is online now   Reply With Quote
Old 04-10-2015, 09:59 PM   #5
fatblockvelle
Just noticed it was an ac Delco part and was curious
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 04-10-2015, 11:54 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
GM stopped installing cruise control as an option after 1970 (listed on SPID). In 1971 and 72 it was a dealer installed accessory. I have a correct accessory set up in my K20 and it looks like this example here: http://67-72chevytrucks.com/vboard/s...20&postcount=3
I don't know enough about the 1970 and earlier factory cruise set up to comment on yours but these did come with a chrome handle IIRC. I'd post to the pickup forum you'll get more comments.
Old 04-11-2015, 07:21 AM   #7
fatblockvelle
Thanks man
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 04-11-2015, 08:22 AM   #8
jaros44sr
jaros44sr's Avatar
The chrome handle was a 72 only item. That alone could be worth some $$$
Looks to be a correct part, is it complete and functioning?
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2015, 09:15 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
This was the cruise activator in 1972 and I believe 71. In these years the GM cruise control did not use a column mounted switch/turn signal control:
Old 04-11-2015, 10:24 AM   #10
fatblockvelle
Hmmmmm... just looks too factory to not be added.... hmmm
1970 chevelle
1971 blazer
1931 ford A coupe.
Old 04-11-2015, 10:55 AM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It may be factory (1970 or earlier) but definitely not factory for 71-72 pickup/K5/Suburban nor the dealer unit that was offered for MY 1971 or 72.
Old 04-11-2015, 12:07 PM   #12
jaros44sr
jaros44sr's Avatar
Looks like I have to get my facts straight before I distort, hope I didn't mislead you to far
pete, if it does a underpass switch, was it lighted. More accessible on the stalk
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2015, 03:21 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Jim from what I recall GM made use of a similar switch after 72 that was lighted. The switch above isn't lighted. Here's what I believe is the lighted, later style cruise switch
Old 04-11-2015, 03:23 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
fatblockvelle see the 68-70 GM set up here: http://67-72chevytrucks.com/vboard/s...41&postcount=7
Old 04-11-2015, 03:26 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
pic - switch actually looks a little different.
Old 04-11-2015, 05:30 PM   #16
jaros44sr
jaros44sr's Avatar
Ok understand, I had the nonlighted switch mounted, but decided to use stalk, since it had easier access.
question on your later post, do you know what years used the chain, as opposed to the cable that goes to the carb
Can you use both switches together, seems you have a pigtail on your switch that I don t have
SAFETY FIRST
AS usual, off topic
Jim
Old 04-11-2015, 05:48 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm not sure if the two switches can be combined for use or not. Wait, on second thought, definitely not so you should sell me the non-lighted cruise master control
I'm really not too up on the other year cruise controls but I believe the 68-70 had a chain. However, there are also period correct aftermarket set up that I believe made use of a chain as well.
