04-10-2015, 09:25 PM | #1 |
What size are the bed strip bolts?
for a stepside. trying to see if I can buy them local.
Thanks, Glenn
Glenn Korec Jamesville NY 64 C20 350ci Turbo 350 tranny 3.73 gear with air ride. 61 Apache10 (wife's truck) 327ci powerglide. http://67-72chevytrucks.com/vboard/s...d.php?t=570100 |
04-11-2015, 08:51 PM | #2 |
Re: What size are the bed strip bolts?
1/4 20 X 1 1/2" cariage bolts.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
04-11-2015, 10:16 PM | #3 |
Moderator
04-12-2015, 01:41 AM | #4 |
60-66 Nut
If you are using original bed strips, those use ribbed shank bolts. I believe they are 1/4-20 x 1-1/2". If you are using aftermarket strips, then you will need carriage bolts as PGSigns stated. The only supplier I know of for the ribbed shank bolts is Mar-K. The carriage bolts are commonly found.
