![]() Join Date: Mar 2006
rally wheels beauty rings HELP?
I have a set of 15' 5 lug rally wheels on my 67 chevy C10 and I looking for a set of aftermarket beauty rings. I am not sure if the correct rings are 2 1/2 or 3 inches wide. Does any of you guys know where to get these that are close to stock gm ones? thanks Rick
Re: rally wheels beauty rings HELP?
i have some good daily driver ones. 3" i think. let me know if you need them.
most of the aftermarkets ive found have tabs that bend easily. ( like from o reillys or autozone )
1967custom |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
If I was you I'd hunt around for originals instead of getting aftermarket ones. I bought aftermarket ones from EBay a few years ago and they don't look the same as the originals on the truck. If your truck is a driver and not a perfecto show truck, originals with a bump or slight scratch would be hardly noticeable.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Do you have the truck style rally's or the corvette style rally's?
The rings are different. |
truck rallyes. theres a pic of them in the for sale section. ill ttt it now
1967custom |
they are 5 lug truck rally wheels 15X9 wheels. Here's a pic of the wheel with aftermarket rings.
still trying to find out if these 5 lug rallys tale 3" or 2 1/2" rally rings? any help? thanks Rick
Why does it matter?
The wheels aren't original! I prefer narrower trim rings. Like 1 or 1 1/2 inch. Make the wheel look deeper. |
I think OE is 2"
1967custom |
Moderator
![]() Join Date: May 2007
You can put any width trim ring on (2", 2.5", whatever) as long as it is for a 15" wheel. Use whatever looks best to you.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
thanks guys I think the 3" cover too much of the 5 lug wheels and work good on the 6 lug wheels. I am going to try the 2 or 2 1/2 ones so you can see more of the wheel itself.
#12 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#13 |
Will a 2.5" or 3" ring fit on a 6.5" van rally ? On my last truck I staggered the trim rings and had narrow ones up front and wide in the rear .
#14 |
No. For the 6.5 rallies, you need 1.5 inch rings. I run. 15x8 rallys and 4" rings.
1982 K10 SWB 1987 V20 - Sold - Doh! |
#15 |
The originals were stainless.
Just be aware that most of the aftermarket stuff is cheap chrome plated steel and doesn't hold up well. Reason the tabs bend so easy too! Mike. ![]() |
#16 |
I have a stainless set of OG corvette ones Im not going to use again. The wide ones for 8" rims.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
