04-11-2015, 11:59 AM | #1 |
Compression Ratio
If I have a 350 w/ a compression ratio of 8.5:1 @76cc chamber volume. What would be the compression if I put on heads w/72cc chamber volume?
04-11-2015, 12:05 PM | #2 | |
Re: Compression Ratio
this should help you out |
04-11-2015, 12:14 PM | #3 |
I looked at that chart, and I do not understand all the data input required. Da! Is the question not answerable without more data?
04-11-2015, 12:35 PM | #4 |
after playing with the numbers i got it to just about match @ 8.51:1 then i reduced the chamber volume to 72cc and got 8.84:1 that should give you some idea where it will be but you wont know for sure unless you add the exact measurements from your engine
04-11-2015, 03:24 PM | #5 |
If a 350's comp ratio is 8.50:1 with 76cc chambers, it will be 8.82:1 with 72cc chambers. Milling .030" off the decks of the 76 cc heads will get you 9.04:1. (I was wrong here. The chamber is not a round cylinder shape, so volume can't be calculated, only measured.)
Is this by any chance a base Goodwrench 350? if so, it is closer to 7.8:1 as delivered.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-14-2015 at 01:26 PM. |
04-12-2015, 11:33 PM | #6 | |
04-13-2015, 10:05 PM | #7 | |
The Goodwrench engine uses a dished piston with 4 valves reliefs, which is around 16 cc total (or maybe even more). My spreadsheet shows that CR as being 7.8:1, which is what Hot Rod magazine came up with. I have no idea why GM rates the engine at 8.5, but I've read on the Corvette Forum where they did the same for 60s and 70s engines. BTW, I was wrong in my post above about milling the heads .030" to get 9.04:1. it's hard to calculate how much the volume is reduced because the chamber is not a round cylinder shape.
