Suggestions/Comments RE: In-Line Fuse Holder Replacement
Greetings, been off the board & hunkered down the last few years
A quick recap: This truck project I started in mid 2009 but had to suspend 8 months later due to separation/divorce. Among other things, I replaced both wire harnesses under the hood with aftermarket. I was just starting to put it all back together when the "stuff" hit the fan. It has been sitting for four years. Now, I am trying to pick up where I left off. This particular problem is & has been with the two in-line fuses that are in the front (runs along the radiator/grill) harness. It's my understanding these are 4 amp fuses and the wires are 18 gauge, both running to the amp-meter. Those tiny glass fuses have always been a pain to remove on both the old & new harness. Yesterday I broke BOTH of those suckers off in the fuse holders & I can't the the remaining metal ends out of either. My plan is to replace both fuse holders with "water proof" in-line blade fuse holders. Questions ---> - Is there any wiggle room with regard to the amp and AWG size of the holder? By that I mean can I get away with using a 5 amp fuse (easier to find than 4) and could I use a 16 gauge wire fuse holder (again easier to find than 18) - What, if any, difference would it make to use an ATC (standard) or ATM (mini) blade. I'd welcome any comments/suggestions about my "plan" Please note: I am a novice.... but follow instructions pretty well. ![]()
1970 CST long bed Fleetside |
Re: Suggestions/Comments RE: In-Line Fuse Holder Replacement
Fuses are there to protect the wiring. So going bigger on the wire gauge is no problem. ATC vs Mini is just preference. IMHO, there's enough leeway that one extra amp is fine.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#3 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I wired in my ammeter when I swapped my gauges, so I never had original wiring.
Larger wire won't hurt a thing ever, just don't go smaller than original. I used 2 parts store fuse holders for the standard glass fuses, and used 5 amps for both. No issues for a year now. You can use any style fuse you want, they all do the same thing. I went with the glass ones since the fuse box in the truck is original and I wanted all the same style.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thank you folks. I found 18 gauge ATC holders and will use 5 amp blades.
