04-11-2015, 08:50 PM | #1 |
signal light problem
i recently purchased a 1983 Chevy C-30 with a 6.2 diesel. I need info on what could be the problem with the signal light. The signal lights will work at times and not work at other times. I replaced the Flasher and that did not fix the problem. I need info on how to fix the the problem or where to test to figure out where the problems at.
04-12-2015, 12:10 AM | #2 |
Re: signal light problem
Start with the easy & less expense things. Check and/or replace turn signal bulbs. Also check your turn signal sockets. From there check for a bad or loose ground. A bad ground can cause all kinds of goofy things with the lights.
I had an issue too with the turn signals, mine turned out to be a bad socket (marker light in the front bumper). I replaced both. And I also had a bad ground on the drivers side front harness. Someone had put a regular bolt in for a ground, instead of a ground bolt. http://67-72chevytrucks.com/vboard/s...d.php?t=664520 |
04-12-2015, 12:52 AM | #3 |
04-12-2015, 04:26 PM | #4 |
78K & 79C Jimmys
start with the ground wires on the rad supports,to the lights.
I've seen if the big batt ground gets old,the power can burn out/bake the small gauge
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-12-2015, 10:26 PM | #5 |
Mine was a bad ground wire connection in the turn signal socket up front.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
