04-11-2015, 09:54 PM | #1 |
Sources for "basic" heater?
Is there a place that stocks the basic heater for our trucks? Not sure where to get one but the deluxe heater I have takes up too much underhood space. Any suggestions or places that stock this would be wonderful.
04-12-2015, 01:08 AM | #2 |
Senior Enthusiast
Re: Sources for "basic" heater?
Junk yards or Ebay. That's where I found mine. I'm not aware of any supplier stocking originals.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
07-25-2015, 08:34 PM | #3 |
Do you know if I can use any 60-66 heater?
07-26-2015, 01:05 AM | #4 |
60-66 Nut
To my knowledge the recirculating heater was only used '60-'63. However, there is no reason one couldn't be installed into a '64-'66. You will use only 2 of the 3 levers on your heater control. The fan lever and the heat/defrost lever.
07-26-2015, 02:47 AM | #5 |
I believe I have one .. Will get pictures tomorrow ... PM'd you ..
07-26-2015, 09:57 AM | #6 |
I got a basic heater from Ecklers. They were having a sale and I grabbed it for 9.95 plus shipping. I had a deluxe heater that was leaking and didn't want to spend the money to have it rebuilt (est. $350 @ the local shop) I had to mid if the housing as the inlet and outlets were for a basic not a deluxe. A little dremeling and she fits like a charm. Of course the heater is on all the time when I open the valve in the engine from the engine but for now I'm fine with the fix.
Posted via Mobile Device |
07-26-2015, 10:25 AM | #7 |
If you don't care about originality here are 2 from Speedway Motors.
http://www.speedwaymotors.com/Speedw...BTU,73715.html http://www.speedwaymotors.com/Flex-A...eater,304.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
07-26-2015, 12:40 PM | #8 |
With the economy heater in a 64-66 I can just adapt the cables to my stock controls? And just run a fan switch? In terms of shutting off hot water to the core I could always add a mechanical valve or does it have that from the factory?
07-26-2015, 02:22 PM | #9 |
Just picked one up from http://www.aspenautoaz.com/ it came packaged well and was in great shape. I was able to get the dash lovers control cable switch and wires as well
http://67-72chevytrucks.com/vboard/s...d.php?t=675881 1972 C-10 SWB 1962 3/4 ton LWB 2011 GMC Sierra LML Z71 crewcab shortbed |
07-26-2015, 02:24 PM | #10 |
Thanks. I got the under hood part out today. Can I safely remove all the sheet metal ducting under the dash too if I intend on going with the economy setup?
07-26-2015, 02:33 PM | #11 |
Yes. The econo box replaces everything inside. If your soft duct lines are hard and cracked you might want to replace them as well.
07-26-2015, 05:36 PM | #12 |
Thanks! The soft lines are completely missing. Removing that heater box from outside really opened up room for the twin turbos!
07-26-2015, 06:48 PM | #13 | |
Twin turbo's awesome!
It only has original paint once |
07-26-2015, 08:13 PM | #14 |
It will only be awesome if I can get the plumbing to fit. Picture a bundle of snakes in a really small space. Thats about what its looking like.
