Old 08-29-2003, 10:26 PM   #1
TIMSPEED
TIMSPEED's Avatar
Better Valve Cover Gaskets: Cork or Rubber?
Which one should I get to fix my leaking valve covers. I'm thinking rubber...but wouldn't cork swell better? Or is swell bad? Also, which type of Permatex should I use?
Thanks!
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 08-29-2003, 10:27 PM   #2
cochino12
It followed me home?
cochino12's Avatar
I've always heard the rubber are better, plus you can reuse them
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 08-29-2003, 11:20 PM   #3
78chevstepside
78chevstepside's Avatar
i got rubber vavle cover gaskets. there reusable almost indestructable. they are a bit expensive but they dont leak no permatex required .
78chevstepside is offline   Reply With Quote
Old 08-30-2003, 01:28 AM   #4
68 Stepside
huh?
68 Stepside's Avatar
Do yourself a favor and don't cheap out if you buy the rubber ones. The cheap ass rubber gaskets leak badly, or always have for me. I personally have always stuck with thick cork gaskets. To each his own :p
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 08-30-2003, 01:51 AM   #5
78chevstepside
The rubber gaskets iam talking about are like aluniumn with rubber coating there and about 3/16 of a inch thick . they are a quality valve cover gasket and cost about 20 dollars. i have took them off half a dozen times with no problem. these gaskets are not cheap and certianly a grade above cork. they are stiff for easy installation but soft enough to seal. cork tend to break for me
Old 08-30-2003, 04:33 AM   #6
68 Stepside
huh?
hey 78, now that I know what gaskets you're talking about, I'd have to agree that those are better :p I've just had better luck with cork, over the el-cheapo felpro rubber gaskets. My next set will be steel-shimmed rubber, like you have.
RIP El Jay
Old 08-30-2003, 04:51 AM   #7
jimfulco
I like cork, but only the good quality ones. The next-to-last set I put on only lasted 26 years, so I could be wrong.
jimfulco is offline   Reply With Quote
Old 08-30-2003, 02:05 PM   #8
apstguy
LED King
apstguy's Avatar
I do believe Fel-pro now makes vavle cover gaskets in the same material that they do for the one piece oil pan gasket.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 08-31-2003, 07:30 AM   #9
scalawag
me
i have never used anything but cork. the trick to reusing them is before you put them back on. clean them with either carb cleaner or pvc pipe cleaner, and clean the top of the heads. make sure the covers arent dented to deep.
most of the problems with covers leaking isnt the gaskets its either how they are mounted or the covers a messed up in some way by over tightening them.
scalawag is offline   Reply With Quote
Old 08-31-2003, 09:34 AM   #10
racedvl
racedvl's Avatar
Yes they do, and I think that's what I'm going with next.
racedvl is offline   Reply With Quote
Old 08-31-2003, 02:13 PM   #11
the baron
the baron's Avatar
Cork...
As I'm a kind of a scrooge , they are manufactured by myself...
The Baron
the baron is offline   Reply With Quote
