04-12-2015, 09:42 AM | #1 |
rear cab mount question
Is this what you guys are using for the rear right behind the door? http://www.brotherstrucks.com/prodin...number=RFS7200
04-12-2015, 02:17 PM | #2 |
Re: rear cab mount question
have you looked to see if that is what it looks like?
ron |
04-12-2015, 03:16 PM | #3 |
It's completely gone
04-12-2015, 04:41 PM | #4 |
1961 crewcab
if you look in my sub build you can see what a stock one looks like, they are a little different...
however since your sub is really rusted , and it is custom, you should be able to just use truck stuff to make it work. if I had yours , and needed to get it solid, I would just order floors, rockers and braces like I was building a truck cab, and then just cut/paste, and fabricate where necessary .
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-12-2015, 06:09 PM | #5 |
04-13-2015, 08:35 PM | #6 |
Thanks.. Prolly just gonna fab sometHing
