Old 04-12-2015, 03:41 PM   #1
Bagged1972
Gas tank trouble
How is going people. I bought a new gas tank yesterday from the charlotte auto fair for my 1971 and today I went to install it but I have seen to have ran into a bit of a problem with it if I get the neck right in the grommet the holes are off and if I get the hole lined up right the neck is off And I can't figure out why. So maybe Yall can tell me something cause I'm sure I'm not the only one who has had this problem. Thanks for your time.
Bagged1972 is offline   Reply With Quote
Old 04-12-2015, 06:16 PM   #2
hugger6933
Re: Gas tank trouble
Can you get it in where you can start the retaining tabs and bolts maybe a couple on top and bottom then try moving the tank where you want/need it to go and then try tightening the straps down so it won't move. You should be able to get it where it is satisfying to you. Jim
hugger6933 is offline   Reply With Quote
Old 04-12-2015, 06:52 PM   #3
sduckworth13
sduckworth13's Avatar
What brand tank is it ?, I've never seen one that the neck sticks out that far.
Scott
sduckworth13 is offline   Reply With Quote
Old 04-12-2015, 07:17 PM   #4
Bagged1972
It's a counterpart tank
Old 04-12-2015, 07:39 PM   #5
sduckworth13
It looks like the gas cap has some sort of sheetmetal collar under it, did you put that on there.
Scott
Old 04-12-2015, 07:48 PM   #6
sduckworth13
I just went out and looked at mine. It sticks out probably at far as yours. I'm going to replace the gasket on it because the one on there is crusty. I bought this truck about a year ago, it was cobbled together by the previous owner. The filler neck is JB welded on. I'm switching cab out soon so I haven't mess with the tank to see why the neck sticks out a foot.
Scott
Old 04-12-2015, 09:24 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I'm with duckworth, that neck flare doesn't look right. Check the measurements on it. I'm guessing wrong tank, maybe a loose one put in a handy box?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-12-2015, 09:56 PM   #8
swamp rat
swamp rat's Avatar
Are you sure the tank is all the way to the passanger side as far as it should go? looks to me like the grommet is the sane size as the larger diameter of the filler neck.
It is kinda odd, i don't think my stock tank stuck out that far before i took it out.
EDIT: just found a pic, it did stick out a bit.. scroll down.
http://67-72chevytrucks.com/vboard/s...&postcount=377
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-13-2015, 12:02 AM   #9
Bagged1972
No that's the way it came. But I came up with one or two ways of fixing the problem. The first one is get the neck sitting right in the grommet and just drill new mounting holes around the tank or I could cut down the filler neck and have it tig welded back up.
Old 04-13-2015, 12:14 AM   #10
sduckworth13
That might be why the guy at the swap meet had it, because of the unfinished? collar on it. I'm just guessing though, but I've never seen one with a similar looking collar on it.
Scott
Old 04-13-2015, 12:22 AM   #11
Bagged1972
Well I actually bought from a company called car and truck parts I think they are out of California but if I'm not mistaken all of there tanks are made like that. I'm thinking just drill new mounting holes would be the best and easiest fix to the problem but I don't know how far the neck is supposed to stick out
Old 04-13-2015, 12:24 AM   #12
sduckworth13
I agree and then you don't get any debris in the tank. Good luck with it.
Scott
Old 04-10-2016, 12:24 AM   #13
1968aj
wish I would have read this sooner. I have same problem with COUNTERPART tank.
1968aj is offline   Reply With Quote
