04-12-2015, 05:49 PM | #1 |
64 body on a 72 frame?
So I have a 72 frame with power disc and power steering and has a 305 and th350 ready to roll. I was wondering if my 64 body will fit on there? I plan to fab the front horns for the 64 and swap the radiator.
I also plan to run a 72 column since its collapsable. Will this work? |
04-12-2015, 08:18 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: 64 body on a 72 frame?
It would less work for you to swap the parts from the 72 to your 64, also the VIN number on the frame would match the cab.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-12-2015, 08:37 PM | #3 |
Swapping the steering box and everything would be less work?
I'm not to concerned about numbers matching since this was a field find. Both trucks are not numbers matching. And it will sonmmeday soon become ls swap. So the body won't bolt in Directly? |
04-13-2015, 12:03 AM | #4 |
Differences:
Front frame horns Radiator core support Radiator core support mount locations Rear cab mount locations I would swap the front suspension stuff over before swapping the bodys. Lots more work w/a body swap....
04-13-2015, 12:05 AM | #5 |
Hmm okiedokie. Thanks all
04-13-2015, 09:42 AM | #6 |
But Found Her 25yrs Later!
Move the goodies from the 72 to your 64 frame.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-13-2015, 01:11 PM | #7 |
i was trying to avoid that. it wouldve been much simplier if the body couldve been laid on the 72 frame. now im more inclined to spend money.... ha
04-13-2015, 02:19 PM | #8 |
The suspension stuff is bolt-in swap friendly. The body swap will require grafting frame horns, relocating mounts, or alot of fudging/spacers to make it work. I would not recommend spacers or fudging things.....
04-13-2015, 03:31 PM | #9 |
If you don't think you're going to have VIN issues, and you know from experience, do what you think will be easier.
04-13-2015, 05:51 PM | #10 | |
always check with your MVO and get it verified so no one ever has a problem, but that usually means going out of one's way ron |
04-13-2015, 06:45 PM | #11 | |
I agree. He just didn't seem to want to take our advice.
04-14-2015, 01:09 AM | #12 |
60-66 Nut
Unless the original frame is seriously damaged and beyond repair, it is always advisable to keep the original frame. There is no advantage to a '72 frame over a '64 other than the disc brakes, power steering and 5 lug differential. All of which can be transferred to the '64 frame quite easily.
