04-12-2015, 06:26 PM | #1 |
Dash knobs n breakers
From looking behind the dash, I'm guessing left to right the first knob is headlights, Second is wipers, third is the choke?
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
04-12-2015, 06:28 PM | #2 |
Re: Dash knobs n breakers
Then there's this one... Says air pull on it. Was this some sort of factory ac on the truck? Or just open vents somewhere?
04-12-2015, 06:30 PM | #3 |
And third is my breaker panel... Looks to me like some of the terminals are missing? Hoping this is why none of my lights work
04-12-2015, 06:47 PM | #4 |
Correct and to the right of the ignition is the lighter if you had that option.
04-12-2015, 06:48 PM | #5 |
Pull out for heat temp control. Turn to the right for fan speed.
04-12-2015, 06:49 PM | #6 |
Might be a good time for some wiring rework.
04-12-2015, 07:37 PM | #7 | |
The fuse clips look kind of rusty though, and that could potentially be the reason why your lights are not working. Except for the headlights ... they are protected by a circuit breaker inside the headlight switch so their wiring doesn't pass through any of the fuses. |
04-12-2015, 07:55 PM | #8 |
the 3 fuses that are in there are rusty and the (TAIL STOP DOME FUSE IS MISSING)
04-12-2015, 09:12 PM | #9 |
I'm thinking I'll replace the whole fuse panel. The wiring in this truck is a mess. There's wires cut, wires tied together, spliced into one another, etc. I'm thinking if I replace the fuse panel first atleast I'll know I've got a clean 12v coming in, then I can trouble shoot the individual circuits from there.
Can these fuse panels be cleaned up?
04-12-2015, 09:15 PM | #10 |
The terminal on the right for the tail stop dome is missing, that's something that should have been on all truck I would think?
04-12-2015, 09:25 PM | #11 |
1961 crewcab
you are down one, the bottom is for a spot light, then tail, then radio, then heater, there is a little arrow to the left.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-13-2015, 06:33 AM | #12 |
Good deal guys. Any idea's on where to buy the fuse panels besides lmc?
04-13-2015, 08:44 AM | #13 |
My B.U. LMP clip is missing, was that done from the factory or someone has pulled it out in the past? Im guessing if its like that from the factory, my truck didn't come with a radio? Anyone else's like this?
04-13-2015, 08:46 AM | #14 |
Does anyone sell just the tail light wiring harness? Something that plugs right in?
Every wire going to my tail lights is cut/broken in two.
04-13-2015, 08:50 AM | #15 |
You can buy any of the harness's by themselves. I use Classic Industries personally or Brothers when ordering harness's.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-13-2015, 09:43 AM | #16 |
Thanks for telling me about industries, everywhere I look its kit after kit, looks like they sell just the tail light harness from firewall back which is exactly what I need!
04-13-2015, 10:11 AM | #17 |
I think American Autowire does there harness's if I remember correct. Real nice quality. Just ordered a forward harness from them to run the HEI.
04-13-2015, 11:10 PM | #18 |
04-13-2015, 11:47 PM | #19 |
If you're going to do that much, you might as well just do the whole truck. It's not all that many wires, and full kits are sold (some even include the fuse panel/fusebox). It's pretty easy to do the whole thing that way, and then you'd know its done right and everything should work. It's a little more expensive, but it sure is a lot easier than trying to trace down every wire in the truck to find which one is causing each specific issue!
04-14-2015, 10:32 AM | #20 |
Moderator
I thought wiring was magic at one time, so I read a book on it from bumping molecules to the entire automotive wiring scheme. It was fun to learn and fun to conduct the entire wiring process myself. I say read (first), collect your parts and tools and have fun. And you'll know everything about it (your truck) when your done.
