Pulling and installing new engine and transmission
I am planning to pull the old engine and transmission and install a new engine and rebuilt TH350 transmission. I am thinking about removing the NP203 transfer case from the truck and then possibly pulling the engine and transmission out together. I have done this in other vehicles but not in these trucks. It looks like there is room to do this but has anyone tried it? Any tips on doing it this way?
Also, any tips on pulling the transfer case? I hear it is quite heavy and I do not have a transmission jack. Will just a floor jack work? Any advice on how to secure it or steady it on a floor jack to lower it? |
Re: Pulling and installing new engine and transmission
I have pulled the trans case on my own and put back in on own with floor jack. I know this may sound a little back woodsy . Do out side just kick it off in the dirt wont hurt any thing inside use a tire need a pickup tire some thing wont collapse.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
I've pulled a 205 before by just rolling under it with a creeper,pull it away from trans & onto me & then rolling out from truck.Put them back in that way 25 years ago,but I bought a tranny jack since then & made job easier. The 208s are way easier,don't used jack on them. I've learned that over the years,work smarter not harder....
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Thanks for the advice. I have done some more research on the internet and have heard it is easier to remove the transmission and transfer case together and then separate them when they are out from the truck. Then pull the engine by itself. So I am considering doing it this way. There is no way I can can handle that thing by hand. Not nearly strong enough. I may see if I can find an ATV jack and use it to pull the TH350 and NP203 together. Does that sound like a good way to go?
Rental places have tranny jacks.
I pulled a trans and transfer together once and I thought it was pretty tough. Now I take the transfer case off first then the trans. I pulled and engine and trans out of a square together and I didn't like that either. I had to lift it pretty high and tilt is a lot. I now take those out separately too. I just use a floor jack too like bigsteve. I wish I had a trans jack though. If i did maybe I would take the trans and transfer together but I don't think it's any easier putting them together on the ground.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#7 | |
I've pulled engine & trans together but I also pull the front clip first.My brother inlaws father told me about this years ago & it works good for me.Especially on any of my lifted trucks.I've always pulled trans case first & then trans,with my jack it's supported better this way too.
