Old 04-13-2015, 08:34 AM   #1
scootermcrad
Wheels and Factory Caps Question
I need a little help from the wheel gurus.
I picked up a super nice set of wheels awhile back. Standard 15" GM 6-lug measuring approximately 6-1/2" from lip to lip on the width and about 8" across the inside of the recessed lug area.
I really want to run the factory style caps on these wheels, but at this point I'm really confused as to what caps I need to be looking for and rather or not I need to install clips on these wheels before i have them painted/powder coated.
These are the factory caps I like. I know there is some difference between 1/2 ton and 3/4 ton, 64, 65, and 66.
Someone just tell me what my options are and if I knew what wheels I actually have, that would probably be helpful also.
Thanks for any clarification on this stuff. I'm lost at this point.
THANKS!
scootermcrad.blogspot.com
scootermcrad is offline   Reply With Quote
Old 04-13-2015, 08:43 AM   #2
1963c-10
1963c-10's Avatar
Re: Wheels and Factory Caps Question
The caps you need will be the 15" caps that measure 10 1/4" on the back or you can use a 16" cap and remove the back inner ring. The 15" cap with the open back 10 1/4" would be easier to source.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-13-2015, 08:43 AM   #3
1963c-10
1963c-10's Avatar
Good thread on the hubcaps
http://67-72chevytrucks.com/vboard/s...d.php?t=501034
Old 04-13-2015, 09:00 AM   #4
scootermcrad
Okay. Good info! Will I need to add clips to my wheels, or do those 15 caps just pop right on?
Old 04-13-2015, 09:00 AM   #5
scootermcrad
Thank you! I will look through this...
Old 04-13-2015, 09:05 AM   #6
1963c-10
1963c-10's Avatar
No....you have the 3 nubs on your rims that will hold on the caps. The clips go on the wheels that do not have the 3 or 4 nubs depending on year of manufacture of the rim.
Old 04-13-2015, 09:21 AM   #7
bonehead
bonehead's Avatar
The caps you have pictured are 64-65 caps, 66 have a rib around the edge.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-13-2015, 09:43 AM   #8
scootermcrad
Good info! Thank you!
So, it sounds like I'm after 64-65 caps that measure 10-1/4"? That definitely seems to jive with the dimensions I have. Great!
This is the look I'm after, right here. White 64-65 cap with black on black tire and wheel combo.
Old 04-13-2015, 09:52 AM   #9
scootermcrad
So... finding a set will be fun. HAHA
Old 04-13-2015, 10:44 AM   #10
scootermcrad
This is what the back of the caps I need will look like, correct?
Old 04-13-2015, 10:46 AM   #11
1963c-10
1963c-10's Avatar
yup
Old 04-13-2015, 11:27 AM   #12
scootermcrad
yup
Great! Thank you!
I really appreciate everyone's help with the info. I feel like I know exactly what I need.
Wheels will go off for coating!
