Old 08-29-2003, 11:28 PM   #1
Ackattack
Ackattack's Avatar
The posi is in
Well I got my posi installed today. Really wasn't that hard, but I was sweating that the bearing wouldn't get delivered today and the machine shop to press them on would be closed all weekend, but it all worked out.
I'm using the stock 3.08 gears for now. Alls I did to install was check the backlash and wear pattern, pull out the old carrier and switch over the ring gears, and put the new posi unit in. I rechecked the backlash and wear pattern and that's it. Took it for a test drive and it's nice and quite from what I could tell over the exhaust and other noise (even shut it off and coasted...but then the ring gear is driving the pinion, rather than the other way around like it is when you're on the gas). I didn't really test it out to see if it worked (both tires spin that is) cause I figured it needed some break in time, and spinning two big ol' 295/50/15 puts a lot of stress on it.
Ackattack is offline   Reply With Quote
Old 08-29-2003, 11:41 PM   #2
Class of 69
Class of 69's Avatar
Sounds good!! You did put the posi additive in with the gear lube, right?? Going around tight corners a few times will get the lube in between the clutch plates and then your good to go do some awesome burnouts!! Be sure to take pics!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-29-2003, 11:44 PM   #3
Ackattack
Ackattack's Avatar
yeah, I put posi additive in there. Actually I had to go get different gear lube too. I was going to put synthetic in there, but it specifically said not to.
I stopped in a parking lot to look it over after a few miles, and then did a few tight circles to each side too.
I guess I'll need line lock soon (got it on my car already...he he)
Old 08-29-2003, 11:48 PM   #4
Class of 69
You've got it all under control!!! LET ER RIP!!!
Old 08-30-2003, 12:12 AM   #5
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
im gonna swap out my c-20 rear end for a c 10.. you got any tips?
how log "should" it take....i took off the c10 pretty easily..but the bed was off and a poly tank wasn't in the way.
thanks
michael
[FONT="Impact"][COLOR="Navy"]Michael
Lowered 1972 C-20 Longbed with 350 and TH350
1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights...
2009 Nissan Versa
I am 26, married, and we had our first baby in July of 2009
Iceman7642 is offline   Reply With Quote
