04-13-2015, 10:06 AM | #1 |
Removed manifold on 283 and OH MY
she's got a pound of sludge and 2 completely blocked coolant passages...now this motor ran and idled great just looks like someone got carried away with the bars leaks...should I percervear and stay the coarse.? Knock out the crud...clean up the galley..put in the manifold, old rad etc and flush motor with atf and the rad several times?
04-13-2015, 02:17 PM | #2 |
Re: Removed manifold on 283 and OH MY
Update ...it was the egr passages that were plugged....doh!
04-13-2015, 02:24 PM | #3 |
Most EGR passages are plugged on any of these old motors lol.
04-13-2015, 02:29 PM | #4 |
Most of those old motors especially the 283 never had egr passages!!
Exhaust heat crossover though! |
04-13-2015, 02:30 PM | #5 |
04-13-2015, 02:55 PM | #6 |
Damn learning every day....heat cross over plugged and will need to chip away at it..will keep the shop vac going
04-13-2015, 09:46 PM | #7 |
So, are you saying you found a lot of oil sludge? Is it collected under the valve covers too?
04-13-2015, 10:25 PM | #8 |
Yes I did, the vent system was messed up..bad maintenance etc
