Fuel tank/pump and rad setup for 5.3 swap
I am doing a 5.3 swap into my 63 c10, it has the radiator mounts that go down below the frame rails, I am wondering if I got a rad that has more cores would work to cool the 5.3 just fine, or do I need a bigger radiator, I would like to use the stock mounting location. If not what is needed, would I have to get the v8 mounts for this year of truck, anyone have any pictures. I will be going electric fans so clearance and shrouds won't be an issue. Also fuel pump and fuel tank time how would the under bed mounted lmc tank work with a aeromotive external fuel pump and regulator work, anyone have a good setup list from their swap. Thanks.
Re: Fuel tank/pump and rad setup for 5.3 swap
I have searched but keep getting mixed amounts of information and spending lots of time searching. Figured lots of people have these same questions so we can get them all in one post.
![]() Join Date: Nov 2009
The mounts that go below the frame are for the 6 cyl. Me personally I was going to use a 283 radiator (lower mounts are higher), but unfortunately that radiator had some pin hole leaks. So I went with a new radiator (from griffin). I had to fab up even wider mounts.
On the fuel tank, I've seen the LMC, looks like you have to modify your frame rail. I've been thinking about a boyd tank with an internal pump. I'm concerned with (what I've read on this board) about external pumps burning up quickly.
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel Last edited by structures; 04-13-2015 at 05:18 PM. |
Here is a link that has alot of your answers. The first link below.
http://67-72chevytrucks.com/vboard/s...d.php?t=456787
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
![]() Join Date: Jan 2012
I did a 5.3 swap in my 65 and used a Speedway Motors radiator. I raised the lower mount up about 1 inch and used the factory lower mounts. The upper I modified the original mount to fit. Here are a couple of pics:
![]() ![]() For the gas tank I got mine from Brothers Truck. I fit great. ![]() ![]() Here is my pump and pre-filter; ![]() Any other questions please ask.
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
Here is the frame mounts and the engine adapters that I used. The frame mounts are CPP engine mounts and the LS engine adapters are from Hooker Headers.
CPP Sheetmetal Engine mounts
Dirty Dingo Sliders Entropy LSx 60-66 C-10 Radiator DT headers Boyd Fuel Tank EFI (engineer approved {myself}.... {t-bone crashed approved}) (came with stealth aeromotive 340 in-tank pump...super quiet) ![]() ![]() ![]() ![]() No leaks... boyd tank built like a brick sh(t house.... {t-bone @ 55} ![]()
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
#8 | |
What type of lower mounts are you using, I have the stock I6 mounts below the frame rail, what would I need to get to make this work, would it be possible to use the stock 02 gm truck rad and make it work. What type of fuel tank do you have for your setup, also what mounts crossmember and how much did you have to move engine back. Since I am changing my front k member to an 80's chev suspension and k member do I need to buy mount plates and mounts for an 80's chev.
{t-bone crashed approved)
That's just not right. |
#10 | |
How many gallons is that gas tank?
#13 |
meowMEOWmeowMEOW
Mods why isn't this in the LS section (we don't come out of our hole sometimes
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
