![]() Join Date: Dec 1999
Engine Brackets and Pulleys
Set Pic. 1 matched set removed from a 1968 Chevy PU with 283 w/ PS these are for short water pump only and are the same as 1967 but will fit many years. Includes both alternator brackets, all 3 pulleys, 1 water pump, and both crank pulleys(with bolts) including the outer that runs off the PS pump. All pulleys are in nice shape, not bent..only issue is one ear on the PS adjustor bracket is broke..this one mounts behind the top bolt hole of the motor mount, it could be easily remidied by using a washer on the bolt..there is still enough meat on the bracket..so to speak....this set is $85.00 SHIPPED
PIC 2 69-72 style short pump. set includes alt. brackets (that bolt to front of driver side head) both PS brackets, and water pump, and inner and outer 2 crank pulley...this set $100 SHIPPED PIC 3 Big Block Crank AC Pulley, PS Crank Pulley, Water Pump Pulley, correct 537 PS pump pulley, PS pump, fluid can(later model with small top) $175 SHIPPED 4 Big Block long pump 2 row water pump, 3 row crank pulleys, PS cradle bracket. 50.00 SHIPPED |
