![]() Join Date: Jan 2015
black tar/glue under windshield rubber
Any idea's on what i can use to clean all the black sticky junk from around the wind shield opening?
vehicle's I own 1968 gmc 3/4 ton camper special 1972 gmc jimmy 1972 Chevrolet nova 1947 ford 1.5 ton dully 1997 f-350 1 ton 2007 Chrysler 300 with hemi |
Re: black tar/glue under windshield rubber
3M makes a cleaner that removes the nasty 3M adhesive, won't hurt paint, I'd try that first.
Thanks i will look for it.
![]() Join Date: Apr 2011
Try some paint thinner.
You could also try using a wire wheel on a drill might make more of a mess so cover everything up.
1971 C10 SWB ...project in the works 2000 Camaro SS....weekend warrior/racecar 2005 Caddy EXT....Tow rig |
horsepower junkie
strongest solvent you can find,brake cleaner works,laquer thinner,carb cleaner...scrape off what you can first,then chemicals for the rest
67 ![]() 71 olds cutlass "S" mom bought new..12.30s@113MPH |
Acetone works well but go easy when you get down to paint level because it will take it off.
- Jim - My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10 and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911 |
