Old 04-13-2015, 08:51 PM   #1
weider1717
first water pump change, question
Ok, changing out the water pump in my 1987 silver ado v10/k10 350. I have the original removed ready to install the new pump.
Question is with the four bolts that bolt the pump to the block, do they enter water jackets and need thread sealant? if so is that the case for all of them? what sealant is best regular thread sealant or do I need blue rtv?
thanks guys
weider1717 is offline   Reply With Quote
Old 04-13-2015, 09:06 PM   #2
kalbert
Re: first water pump change, question
Yea, they all are open to the water jackets, you have to use sealant. I've always used pipe thread goop, gob it on the threads of the bolts and screw em in.
kalbert is offline   Reply With Quote
Old 04-14-2015, 10:46 AM   #3
Bigstevex4
Bigstevex4's Avatar
There 1 that is lower on drivers side but putting some sealant all all is ok to make sure. Its easy enough to check for future projects blow air in the hole.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 04-14-2015, 10:51 AM   #4
enaberif
Permatex thread sealant all 4 bolts then just do em up.
enaberif is offline   Reply With Quote
Old 04-14-2015, 02:07 PM   #5
greg64
greg64's Avatar
Originally Posted by enaberif View Post
permatex thread sealant all 4 bolts then just do em up.
x2
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 04-15-2015, 08:56 AM   #6
tucsonjwt
Oops -I did not use thread sealant on the bolts when I changed mine. I don't see leaks - what does that mean? I did not see evidence of thread sealant on the bolts when I changed mine - it looked like a factory GM pump. Should I drain the coolant and remove the bolts, one by one, and add sealant to the bolts? If I do that, do I have to leave the coolant out of the engine for a day before refilling with coolant? If so, what type of sealant should I use?
tucsonjwt is offline   Reply With Quote
Old 04-15-2015, 09:23 AM   #7
enaberif
I already said what type of sealant to use. The issue with not using it is that you can have the threads weep and cause moisture around the water pump.
It may not happen right away as the engine isn't under pressure.
Old 04-15-2015, 05:48 PM   #8
weider1717
I put permatex high temp sealant it's WHITE was this was you was talking about? it's just regular ole sealant NOT rtv which I hate using I view rtv is a billy bob way to seal things up. for future reference was the high temp needed? or the reg white tube with blue writing on it be fine? I figured to be safe why not but curious.
GUYS.... let the gasket do what the dang gasket is meant for no rtv is needed on gaskets!!!! I hate seeing passed owners of my vehicles using that crap.
Old 04-20-2015, 08:00 AM   #9
Desert1957
Desert1957's Avatar
No sealant required, bolts are INSIDE the gasket holes.
Desert
Desert1957 is offline   Reply With Quote
Old 04-20-2015, 08:50 AM   #10
enaberif
Attachment 1393204
Desert
Its HIGHLY advised to use permatex and I'm not talking about using an entire tube. You put a very light skim of it on the mating surfaces which will add an extra layer of protection and will hold the gasket from moving.
I have done this plenty of times and never ran into any issues OR leaks.
Old 04-20-2015, 11:33 AM   #11
Bigstevex4
Bigstevex4's Avatar
Attachment 1393204
Desert
If the hole is drilled into water way it will leak past threads up bolt and out by bole head.
90 Jimmy parked
In memorium
Old 04-20-2015, 12:34 PM   #12
Desert1957
Desert1957's Avatar
Never seen it , in 40+ years of repairs.....
Old 04-20-2015, 12:35 PM   #13
enaberif
Happens all the time. Same with the bolts for the cylinder heads and intake manifold bolts. Don't seal them properly you'll get weepage.
Old 04-20-2015, 01:57 PM   #14
Bigstevex4
Bigstevex4's Avatar
Made for a reason.
90 Jimmy parked
In memorium
