what engine is this ?
I'm trying to figure more and more about this truck. Does anyone know what engine this is by looking at pictures ? Any help would be great, thanks.
![]() Join Date: Aug 2012
Re: what engine is this ?
looks like a good ol' SBC w/ Throttle Body Injection. Gut tells me a 305 but i'm sure i'll be corrected if i'm wrong by the more knowledgeable.
Most everything in the picture will bolt onto every SBC.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
My guess would be a Vortec based TBI engine around "93 used in trucks or vans of that era. I have the same looking unit in my '46. in my case it's a 350, and no, not all SBC parts bolt together as the Vortec blocks have different intake mounting, center bolt valve covers etc. Very good engine by the way.
Rob
My '47 C.O.E build |
#6 | |
The Vortec has a full circle rear main seal but other than that all early pieces will bolt to the block. It's the bolt angles on the intake side of the heads that is different. I believe that the four center bolts go straight up and down rather than at an angle like the early bolts do.
Vortec heads call for a Vortec compatible intake or a an early intake that was modified to work.
the vortec heads only have four bolts on each side of the intake manifold. two front two rear and the angle they go into the head is more up and down than earlier heads.
1957 3100 ![]() 1950 5 window |
Thanks for info guys, so from what I take its a 350 vortec 5.7L . So my next question is what's the easiest way to get more power out of this bad boy, different carb ? intake manifold? Any advice would be awsome, thanks again.
Vortec wouldn't have the two middle intake manifold bolts next to the throttle body. So it's a normal TBI 305 or 350 from 1988-95. If you look down on the top back of the engine block behind the distributor it should have the casting numbers and either 5.0 or 5.7, which would be the 305 or the 350.
There isn't a whole lot you can do to a TBI small block performance wise before you have to get into retuning the computer with chips. Speaking of which, what's the part number on the sticker on the computer in the truck? My recommendation would be leave it be and enjoy the reliability, reasonable MPG and smooth running. 1995 TBI trucks: 5.0 V8 = 175 HP@4200rpm, 265 ft/lb@2800rpm 5.7 V8 = 200 HP@4000rpm, 310 ft/lb@2400rpm The dangling end of the PCV vent hose there is letting unfiltered air into the intake. It's supposed to be plumbed to let filtered fresh air into the drivers side valve cover. |
what truck is that engine in?
RanchTruck is right, there's not a lot you can do with those TBI engines without doing away with the computer completely and installing a carb and distributor. if you have a 4L60E trans that's not very feasible. That's a really good basic engine, smooth, good torque, responsive. Hard to improve on without getting in deep. |
#13 |
It's kind of one of those "if it's not broke don't start fixing it' things. As the guys said those engines are pretty well dead nuts reliable and pull a lot better gas mileage than a carbed engine is going to.
#14 | |
#15 |
![]() Join Date: May 2007
another vote for leaving it tbi! mpg, ease of driving, all the same reasons. I have seen a lot of guys take something running well and end up with a torn apart driveway paperweight because they wanted a "little more _____" fill in the blank.
what a score, I was saying 305 under my breath because 9 times of 10 thats what guys who hope its a 350 have.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#16 |
That's a 1993 truck PCM. It's the later more capable computer. It is tunable if you go that route, but it's a steep learning curve. binderplanet is a good resource for TBI stuff, as is thirdgen. So there is a ton that could be done to the engine, but you will have to learn how to manipulate the code in the computer to compensate for it.
Or, you could keep it as is and enjoy. Your truck looks to have a pretty clean and complete swap in it, so I would keep it rather than regressing by trying to swap in a carb and using an aftermarket transmission controller. |
#17 |
You've got nice setup there. I vote to leave it alone as well. However... pics of the truck are necessary sir!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#18 |
#19 |
OOOOOOHHHHHHHmigosh~! Looking for words.........nothing........Speechless.....can't breathe.......
#20 | |
Hey... that's a nice looking rig.
#21 |
Awesome truck dude
#22 |
![]() Join Date: Aug 2010
A set of shorty headers would help. But keep the TBI.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#23 |
#24 | |||
How much have you driven the truck before deciding you need to modify the engine? I've caused plenty of mayhem with a stock TBI 350 in a heavier truck, so it should be fun to drive as is. |
#25 |
Those generation of ECMs use a chip that you have to erase and flash. I'm doing a TBI in mine and have researched tuning a bit.
The easiest route is an EBL Flash upgrade from http://www.dynamicefi.com/. His set up also provides tuning software. There's a lot options out there. |
