04-14-2015, 09:23 AM | #1 |
65 C10 with 91 Suburban K member swap
I tried finding a 100% yes or no answer on this, but haven't been able to find what i need. I have some one that has a front end already removed out of a 91 burb, and i was wondering if i could swap it out with my 65 frond suspension. i don't mind drilling a few holes, but i don't want a complete reworking of my front end. He also has a 79 c10 front end as well, but it is still bolted into his junker parts truck. Any insight would be greatly appreciated. Thank you.
04-14-2015, 09:45 AM | #2 |
Re: 65 C10 with 91 Suburban K member swap
they are the same 79 c10 to the 01 suburban.. i have a 91 suburban front suspension in my 63.
04-14-2015, 09:50 AM | #3 |
67-72 parts collector,…
Completely reworking the front end would depend on the condition of the donor crossmembers.
Both will work. But bolting a wore out 79 or 91 crossmember into your truck is no better than your original 65 crossmember. Personally I would leave the 65 crossmember and engine stands in place, and use the steering and a-arms from the donor if they are in good condition.
04-14-2015, 10:01 AM | #4 |
Ok i just wanted to see if the 91 would bolt up like the 79 would. (with a few holes drilled) The 91 is in alot better shape than the 79. the guy wants to sell the whole member, but if i can get away with just canibalizing the 91 after i get it i might do that. What do i need to make sure i grab other than the a arms, spindles, brakes, and ect?
04-14-2015, 12:35 PM | #5 |
Brake lines and all hardware is always helpfull.
Also if you want too while you have the spare laying around you can pancake it. |
04-14-2015, 01:11 PM | #6 |
Pancake it?
04-14-2015, 08:11 PM | #7 |
It was s when you cut a 1.5 inches out of the thickness to increase ground clearance or drop.
