Old 08-30-2003, 01:03 AM   #1
walker
walker's Avatar
Tires for my '67 lwb C-10
I am looking for some tires to put on the rear of my '67 C-10. I have 235/70r15's on all four right now, but the back looks silly with those little tires on it. I also want taller tires in the rear to help lower my rpm's as I have 4.11's in the rear. The rims I have on there are 15x8 steel rally wheels. If I need to put bigger rims on the back I can do that but would prefer to keep the same ones. Any reccomendations on a tire size that would fill up the wheel well, not rub, and look good???
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-30-2003, 01:39 AM   #2
Project1970
14.1 @ 96MPH
Project1970's Avatar
275/60R15 Yokohama Avid S/T's if your truck is mostly street driven. They're like Radial T/A's, with less suck and more rock
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 08-30-2003, 03:29 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
255/60/15 fronts and 275/60/15 rears here. Oh btw they are BFG's
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 08-31-2003, 01:24 AM   #4
nate68
radial T/A's suck in the rain. dry they are fine
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-31-2003, 01:47 AM   #5
Hotrod70C10
Low & Slow
I've never had a problem with either sets of radial t/a's that i've had. Then again I drive like a grandpa everywhere I go.
4.5/6 drop
Old 08-31-2003, 05:12 AM   #6
Nova_Cobra64
Nova_Cobra64's Avatar
If you are looking for something larger in diameter to bring down your rpm, then you have few options. Your current tires are 28" tall. They are the same diameter as the 275/60's (which I find to be about the perfect size tire for the rear of anything based on the width and diameter). If you really want to go taller, then you could go to a 285/70, which has a diameter of 30.8", or a 255/70 with a diameter of 29.1".
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 08-31-2003, 11:52 AM   #7
Project1970
14.1 @ 96MPH
To elaborate a bit...I've found the traction differences between the Radial T/A and the Avid S/T to be night and day. There is a definite advantage with the S/T's in the dry, and wet...well, there's simply no comparison. With the T/A's, I've had the tail end try to swing around under light throttle when there was a puddle! The S/T's just keep on sticking.
On top of that...my T/A's were done at about 15,000 miles. The S/Ts have nearly that many and have at least half of their tread left.
Old 08-31-2003, 12:21 PM   #8
Hotrod70C10
Low & Slow
Hey project1970, How much did it run you for all 4 tires?
4.5/6 drop
Old 08-31-2003, 12:30 PM   #9
low 84
low 84's Avatar
30X9.5X15 or 31X10.5X15
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 08-31-2003, 01:20 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Tire rack sells them for $60 each.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
