Old 04-14-2015, 11:10 AM   #1
rudyyloverboiii
muncie sm420
My four speed is starting to go bad on my 64. Anyone swap it out with a 5 speed manual that not much modification or none of it was required. Thanks for the help I would really appreciate it.
rudyyloverboiii is offline   Reply With Quote
Old 04-14-2015, 11:18 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: muncie sm420
I did an AX15 5 speed swap, detailed here, http://67-72chevytrucks.com/vboard/s...d.php?t=475370
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-14-2015, 06:08 PM   #3
par4tom
Re: muncie sm420
I did an NP440 swap for my 420. It has overdrive and there is one for sale on ebay right now for less than $1000.
It will bolt right up and there are several threads on the various forums on this tranny...
I like mine with the .73 overdrive...especially if you drive the highways a lot...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 04-15-2015, 03:44 PM   #4
josephmichael09
Re: muncie sm420
Ok so this thread caught my eye and I'm hoping we get some good information here...
So I have this same transmission, and it is leaking a bit of oil. I am not sure if I should go through the trouble in replacing the seals or replacing the transmission. The transmission ratings that I have found give the transmissions "smoothness" is 3 stars out of 5.
Honestly, I think I want to go with an automatic. What is involved in swapping transmissions? What to look for when searching for a new transmission? What generally needs to be modified?
Also, my uncle purchases a lot of old trucks and cuts a lot of corners, so I am a bit skeptical of the advice he gives me, but he mentioned a 700 transmission. What is a 700 transmission?
josephmichael09 is offline   Reply With Quote
Old 04-15-2015, 09:19 PM   #5
spookylynx
spookylynx's Avatar
Re: muncie sm420
700R4.... probably
spookylynx is offline   Reply With Quote
