Got a 'crick in my bed
Well, i'm working on my truck the other day, and figured it's time to address this little situation.
I had a wreck with this truck about 10 years ago in Los Angeles. I hit a wall on the 110 northbound at about 60-70 mph. We got the frame checked out, and everthing was still good, and everything was still square. The bed, however is from a donor truck, and it has sat like this ever since. ![]() The question, is could this be an issue with the bed, or with the frame? Were we lied to? I was going to shim the right side up a bit, but thought i should ask first. thanks guys!
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Got a 'crick in my bed
If you have never removed any mounting blocks or shims or moved the bed around . . .
Could it have been like this before and was never noticed? You could check the height of each mount first to determine if they are different on one of them. Maybe someone put a old piece of ill fitting wood block in there.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-14-2015 at 12:38 PM. |
Had the same issue with my '67, turned out to be worn out shocks. Check out your suspension components as well
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
i've looked for any existing shims, and i've never noticed it before. I have air shocks on the rear and are relatively new. (about 6 months) both are only holding about 10 psi.
I was going to shim it with some rubber hose, but wanted to check to see if there is/was a proper way to correct this
1961 crewcab
I would jack it up, and unload the suspension, then level the frame rails on the jackstands. then check the bed...
this would rule out worn out springs, shocks, or bent suspension components
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thats a great idea. I'll give that a shot tonight. it'll be tomorrow before I can report back. thanks guys!
Post Whore
![]() Join Date: Mar 2013
The bed on my 66 c10 does the same thing. lol Same way to!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Funny. The bed came off a donor 66 that was totalled in front.
![]() Join Date: May 2007
mine did that exact same thing. turns out that someone in a previous ownership needed to take the bed off and one of the bolts was stubborn so they cut the crossbrace slighty for access. over the years it sagged in that corner. you can see the cut in this picture, the exhaust pipe is pointing almost straight at it.
![]() I redid the bed floor braces for a tilt bed but if this is also your problem (either cut or otherwise compromised) you can jack up the corner of the bed and reinforce the cross brace.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
![]() ![]() Join Date: Jul 2002
Bed would could be rotted more on one side. As mentioned the rubber shims they came with, but normally are never used again if the bed was removed at all, could be rotten missing or? The cross seal could be bent or rusted ad could the mounting points on the frame.
As mentioned I would put it on jack stands to rule out suspension issues, then check all the mounting points. Since that isn't the original bed I am going to assume that it is something in the bed and not your suspension/frame.
OK,
got the truck on stands, looks like the problem may be the bed? Putting it up on stands and the bed still has a SLIGHT twist to it. what should I do now?
1961 crewcab
another thing I thought of: how does your cab mount rubber look?
maybe take some measurements from the cab to the frame and make sure that it isn't the cab that is sagging. apart from that: if it is not suspension, or cab mount rubber, I would look into shimming the bed, maybe check your mounting points on the bed to see if they are level with the frame...
#13 |
The bed seems level with the bumper so I don't think shimming it will work.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#14 |
with the truck on flat ground (slab floor would be best) measure from the top of the rear axle to the bottom of the frame on each side and on the front measure from the ground to the frame and report back
#15 | |
Never Ending Projects
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#16 |
Yep. Frame is twisted. Difference at axle is about .25" side to side, at the rearmost part of the frame its closer to .75"
#17 |
NOT necessarily a bent frame ....Next step put stands under the front frame horns lift at least 4 inches using a 4' level across the frame as close to the stands as you can get shim until it is level now do the same just behind the cab after those 2 points are level check and see what the rear of the frame looks like with the level if it is level then the "twist you are getting is just spring sag from side to side
#18 |
hmmm. I'll have to give that a shot. I'll try to get this done during my lunch this afternoon.
#19 |
My bed does the same thing, but in the other direction. I need to get mine on jack stands also and see what's going on. Did you get the chance to look more at yours?
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 Last edited by ChrisDollins; 04-18-2015 at 08:24 PM. |
