04-14-2015, 03:03 PM | #1 |
84 wiper delay module same as 85-86?
I have a Silverado 1984 with the factory delay wipers in the column. I only get lo/hi, so I went to the dealer to see if I could get a new module that sits under the column. The rep looked it up and said 84 is no longer available. He looked up later years and said they could order an 85-86 delay module. He said it should work because 84-86 use the same delay wiper switch part number. My question is, what is different about 84 that it has a different part number for the module and will the new 85-86 work in my 84 without burning out? Thanks.
04-14-2015, 05:23 PM | #2 |
Re: 84 wiper delay module same as 85-86?
They look the same but not sure about the function.
04-14-2015, 05:33 PM | #3 |
The dealer rep said they probably revised something in the circuity to make it work better but it sounds like he was just guessing.
04-14-2015, 06:06 PM | #4 |
Would not surprise me but some here may know more than I do about this. GM parts people should be able to access a parts history to see if a part has been revised to a different number.
04-15-2015, 02:00 PM | #5 |
The rep said the 1984 number wasn't superseded so that's why I wasn't sure the newer one would work correctly.
04-16-2015, 09:47 AM | #6 |
What are your options at this point? Seems like a used one might be the way to go. You can have mine if you pay for the ride or probably get one locally for about the same price as postage, especially if you bundle it with some other used parts that you may need.
04-17-2015, 05:07 PM | #7 | |
I may take you up on that offer. Seems to be slim pickens in the wrecking yards, one place laughed when I said what year. I was like huh, and he said that if its older then 10, they crush it. Is there a way to test the switch to see if its working? Dealer wanted over $100 for just the in column switch.
04-18-2015, 02:14 AM | #8 |
Around here they leave 'em in the yard a week or two then crush. They said they run out of room if they don't. I know the wiper switches are expensive. I try to keep new ign.,dimmer, etc. on my shelf but can't afford wiper switch but really never needed to replace one. Don't know how to bench test one, just plug it in and try it is all I know.
04-18-2015, 07:58 AM | #9 |
Moderator
Download the wiring diagrams and look at them. If the 84 has the same pinout as the 85 & 86 unit I'd try it. The GM wiper systems switch the ground not the hot.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
04-18-2015, 11:53 PM | #10 |
Interested to know as well
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
