Old 04-14-2015, 05:30 PM   #1
JacobSchni
JacobSchni's Avatar
16/20 gallon tank?
I just received a 20 gallon tank for my 83 k10 longbed though lmc truck. The magazine said that long beds are 20 gallon tanks. Is that true, do all long beds come with the 20 gallon tanks? Mine has two 16 gallon tanks.
JacobSchni is offline   Reply With Quote
Old 04-14-2015, 06:46 PM   #2
1970pelle
1970pelle's Avatar
Re: 16/20 gallon tank?
My 86 C20 long bed has two 16 gallon tanks.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 04-14-2015, 07:37 PM   #3
ray_mcavoy
Most longbed trucks were equipped with 20 gallon tanks. But when the dual tank option was added, some longbed trucks were equipped with 16 gallon tanks.
The tank sizes are listed in the vehicle info kits from the GM Heritage Center. But I haven't gone through them all to see exactly what factors determined whether or not a particular longbed would have received dual 20 gallon vs. dual 16 gallon tanks.
ray_mcavoy is offline   Reply With Quote
Old 04-15-2015, 01:13 PM   #4
Bigstevex4
Bigstevex4's Avatar
Replaced my tank it was a 20 gal 83 long bed. you can use ether one.
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 04-15-2015, 10:12 PM   #5
tucsonjwt
If you have 16 gallon tanks on a long bed you will need extension tubes and two extra short hoses to connect to your filler neck. The 16 gallon tanks are shorter than the 20 gallon tanks, so you need the extension tubes/hoses to reach farther forward from the filler neck. Ebay sometimes has filler necks and hoses for sale used, but I don't think they are available used. I have seen 16 gallon tanks on long bed trucks. I think 16 gallon tanks may have been standard equipment with 20 gallon tanks an optional choice.
tucsonjwt is offline   Reply With Quote
