04-14-2015, 11:06 PM | #1 |
Registered six offender
Just picked up a 1963 Chevy it has a straight six in it and everything seems to be stock. Just wondering what you guys are doing to spice these things up a bit. Not looking to have a race motor but if like to get a bit more power out of this thing. Also not sure witch six is in it.
04-14-2015, 11:32 PM | #2 |
Post Whore
Re: Registered six offender
4 inch sidecovers and you'll have a 230, 6 inch side covers and you have a 292. For what your desiring....4 barrel, headers, hei and 5 speed would be optimum.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-15-2015, 01:32 AM | #3 |
You should also add an electronic distributor or a pertronix module
Do a search for tricked out six
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
04-15-2015, 07:26 AM | #4 |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-15-2015, 10:11 AM | #5 |
Cool thanks guys. Also I don't know if you guys have seen this before( I don't know of this is stock) but the trucks rear suspension has a half a leaf spring and a coil sping?
04-15-2015, 10:34 AM | #6 |
Post Whore
You have the "Heavy duty" overload springs.
04-15-2015, 10:37 AM | #7 |
Look something like this? As TJ said they are auxiliary springs
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-15-2015, 10:45 AM | #8 |
Its likely what your referring to a half leaf spring is actually overload springa . they attach near the rear of the frame and the end will bump stop against a metal attached between the rear housing and trailing arms. Heres pictures of the souped up 250 six in my 66 GMC. Its a 68 250 bored .040 offenhauser 4 bbl intake & valve cover. Hedders and a RV cam. Hei ignition. Backed by a powerglide trans.
04-15-2015, 10:51 AM | #9 |
Post Whore
FWIW, Here's a picture of my 292 in my 66 chevy. Bone stock with a 600 edelbrock, clifford intake, clifford headers, and HEI. Pulls perrty darn good for being as worn out as it is. And here are a couple performance videos.
https://www.youtube.com/watch?v=7b3OpLWMb4E https://www.youtube.com/watch?v=YoiM0nIA_7c https://www.youtube.com/watch?v=ifh4eU5bUAo
04-15-2015, 12:02 PM | #10 |
Thank you guys very much for your responses also I was wondering if I take out that extra spring will it drop my truck or would the drop be too much without a notch? I also just emailed pertronix to see what set up they would recommend for my truck.
04-15-2015, 12:06 PM | #11 | |
Post Whore
04-15-2015, 12:32 PM | #12 | |
04-15-2015, 12:34 PM | #13 |
Post Whore
No no no. lol This HEI is a distributor and has everything you need. The pertronix is a replacement for your points distributor. An HEI is a whole different setup. That hei will bolt in and all you'll need is new plug wires and to hook your wires on.
04-15-2015, 12:47 PM | #14 |
I understand what the hei is I've used them in other sbc builds I've done in the past. I've just never used the pertronix module. So I can use my stock distributor and replace the points with the pertronix module? Also if running the pertronix module I'm assuming I still need to run the coil? Where as the hei has the coil in the distributor?
04-15-2015, 12:51 PM | #15 | |
Post Whore
04-15-2015, 02:17 PM | #16 | |
Also....3 springs would be the 60-66 set up, they went to a single spring I believe in 67 and they will interchange.
04-15-2015, 04:20 PM | #17 | |
What is the chain going from the block to the frame for?
04-15-2015, 04:42 PM | #18 |
I'm just glad to be here!
Torque limiter so the engine torque does not rip the driver side motor mount apart...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
04-15-2015, 05:41 PM | #19 |
04-15-2015, 07:30 PM | #20 |
The gasket should come with the exhaust manifold gasket set.
04-15-2015, 07:31 PM | #21 |
here is a pic of my 250
04-15-2015, 08:54 PM | #22 |
Anyone know what this motor is?
04-15-2015, 08:56 PM | #23 |
Post Whore
You have a 292. Great engine for spicing up. I've done several tests on my 292's so hit me up anytime you need info.
04-15-2015, 09:34 PM | #24 |
That large bypass hose is a 292 thing too
04-15-2015, 10:40 PM | #25 |
six bangers are cool drove em for yrs for a moment wish I still had one but just for a moment I have a sweet set up now and injoying that (350/350)..
picked up a third pedal set up for my truck because you never know what tomorow will bring Might go back to 4spd ....Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
