Old 04-14-2015, 11:50 PM   #1
dantimdad
dantimdad's Avatar
Bags for a c60
I am contemplating buying a 65 c60 with little to no rust from a farmer.
It's been in the field for 10 years under some trees. The paint is shot, every rubber seal is shot and the motor turns over but won't run.
I love the look of the truck and want to actually use it. But, I would like to improve the looks of it some more.
I really want to lower it but be able to haul a car if need be. What kind of bag setup would this take? Or, do I even need to bag it? A static drop would be fine with me.
Also, is there a way to switch it to discs in the front but still retain the factory wheel setup?
Thanks,
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline   Reply With Quote
Old 04-15-2015, 08:04 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Bags for a c60
You would need to find a more modern truck with the wanted parts and swap them over. It might be advantageous to just swap the bodies over to another good chassis
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-15-2015, 05:07 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Bags for a c60
I was looking at one of these 1991 and up c/3500 hd's the other day, thinking that a 60 series cab and clip would look really good on the chassis.
they are rated pretty heavy and would probably work for car hauling.
here is the wiki:
http://en.wikipedia.org/wiki/Chevrolet_C/K
imo you are probably opening a big can of worms trying to modify the og. 65 60 series chassis and suspension.
if that is what you want to do, I would look at "Z ing" the frame in the front, and maybe a the same in the rear.
a couple things I ran into w/ my 66 60 series:
insurance, I have to carry a separate commercial policy on it because of the weight.
registration, also because of the weight it costs me double that of my c/10.
wheels and tires, new tires are expensive, and if you have the old split rim style 9.00 20's you can't find a tire shop that will touch them, I was lucky and after a year of looking I found a rare set of 1965 22.5's that are not a split rim and will take a modern tire.
a couple times in that year I almost bought another 60 series just for better tires..
this yellow 61 is a 60 series that was placed on a 63-66 1 ton frame, and came out nice.
Old 04-16-2015, 10:30 PM   #4
dantimdad
dantimdad's Avatar
Re: Bags for a c60
Thanks guys. I might just pass on it. If he comes back with an insanely low price I will get it and look around for another chassis.
Steven
Old 04-16-2015, 11:04 PM   #5
jonzcustomshop
1961 crewcab
Re: Bags for a c60
check out this thread too: for the chassis swap...
http://67-72chevytrucks.com/vboard/s...d.php?t=662382
Old 04-18-2015, 01:07 PM   #6
dantimdad
dantimdad's Avatar
Re: Bags for a c60
I have almost decided, if we reach a deal, That I will keep it on the frame and get new wheels and lop off the bed to 10 or 12 feet. I will figure out a way to lower it about 6 inches and be done with the chassis. I want to keep it able to haul stuff.
I will probably drop in a diesel engine as well if my buddy comes through with one. If not, I will rebuild the 292 and take steps to pep it up. I built one in the 80s that was a beast and not as much was available back then so it should turn out better this time around.
Cross your fingers the deal goes through soon. It took about 6 months to even get him talking to me about it.
Steven
