04-15-2015, 12:01 AM | #1 |
87 exhaust manifold torque value question, inner vs outter
Done some research and i have torque wrenches so why not do it right..
Looks to read that my 87 v10 5.7 exhaust manifold to block torque values are 26 ft lbs on the two inner tube bolts and 20 ft lbs on the remaining bolts. this doesn't seem right to me..first are those intact the correct values? 2nd why aren't they torqued evenly.. don't want any leaks so figured I'd ask! thanks |
04-15-2015, 12:03 AM | #2 |
Re: 87 exhaust manifold torque value question, inner vs outter
I've never torqued and never had leaks. Just snug em up and give it a bit more.
04-15-2015, 02:25 AM | #3 |
Parts and more parts
I do not torque my exhaust bolts, I just use my 3/8" ratchet and the a socket, with no problems for many years. I do however use teflon tape on the threads so that they do not back out after tightening them. It works pretty well and when you want the bolts out, they come out.
Frank |
04-15-2015, 01:23 PM | #4 |
The torque values sound about right 3/8 bolts can go up to like 40. its not going to hurt any thing at those values. 87 v10? 5.7 Chevy has no V10 Eng. or does that mean something else?
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
04-15-2015, 01:30 PM | #5 |
V10 is the designation for 4 wheel drive (half ton) squarebody from 87-90. New body style kept the c/k designation.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
04-15-2015, 01:34 PM | #6 |
Ok something new have 90 Jimmy never knew that.
Just looked that's what the say 26 and 20 and older 350 calls 25 all around.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero Last edited by Bigstevex4; 04-15-2015 at 01:41 PM. |
04-15-2015, 05:46 PM | #7 |
Went with the 26ft lbs on inners and 20 ft lbs on the rest. we shall see
04-16-2015, 12:55 AM | #8 |
If that is factory specs it should work but the factory also used locking tabs that get thrown away a lot of times. Personally I have never reused those things.
