04-15-2015, 12:05 AM | #1 |
Gas gauge needle bouncing
Hello everybody. I'm usually on the 67-72 page, but I also own a 99 1/2 ton 4X4 Suburban.
As the title states, my gas gauge is moving around quite a bit. I'm thinking it's a ground or sending unit issue, but I figured I'd run it by you guys first before I go chasing it the wrong way. Appreciate any tips you might have. Thanks, Jason
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
04-18-2015, 10:10 PM | #2 |
Re: Gas gauge needle bouncing
I have 99 Sub 4x4 (156,000 miles). About 2 years ago I had the same issue. I didn't do anything about it. 3 months later the gauge stopped working, so I just kept track of miles on the trip odometer and filled when needed. Last year the fuel pump went out. A new pump with sending unit and new electrical connectors at the pump harness connection point and all was working again. My gas gauge needle does still have a slight vibration though. Maybe the spring in the gauge for the needle fatigues over time. If the needle moves a lot, I'd try replacing the electrical connectors at the pump/sender.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
04-19-2015, 12:00 AM | #3 | |
Things sure move slower here than the 67-72 board. If no one answers a post in an hour or so over there it can get buried pretty fast!
04-20-2015, 12:01 AM | #4 |
Cluster King
This may not be your issue but have you checked for a broken baffle inside the tank. If the tank baffle has come loose it will come in contact with the float and cause an erratic needle movement on the gauge.
Just a thought, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
