![]() Join Date: Apr 2015
Help w chrome windshield trim please
Fairly new here, first just want to say thanks to all the talented folks out there willing to share their time & talents, its really motivating for those of us with less experience & skill.
Next, I have a donar 65 chevy I am taking remaining unused parts off of & will attempt to post soon. It is a custom cab w the chrome windshield trim. I need tips for removing the trim without damage, especially the clips, looks like they should just pop off but want to make sure. Thanks |
Re: Help w chrome windshield trim please
If you are talking about the exterior chrome trim, that is held in the gasket by pressure fit. To remove the chrome you will have to cut the gasket all the way around and remove the glass from the cab to get the trim.
Thanks for the quick response 68JOHNDEERE. Soon as the rain stops I'll give that a try.
Once you cut the gasket you will remove the entire assembly (glass & trim). I like to slide the trim out of the revel clips as opposed to prying the clips off which makes them prone to get dents.
Reinstalls same way. Trim goes in gasket, windshield goes in gasket and installs as 1 unit. Trim clips go on after the windshield is reinstalled. Also recommend a Precision brand gasket over any of the rest....trim or non-trim
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Senior Enthusiast
To clarify, never try to pry the trim out of the gasket. Once the glass/gasket/trim assembly is off the truck, peel the gasket off the trim. Once the trim is free of the gasket, just slide the pieces apart and the clips will slide off the ends of the trim with no effort.
Ask again for more tips when it comes time for installation. Above all protect the end caps/clips from loss. They are essentially irreplaceable. If you lose one, the set is basically useless and few people are willing to give one up, rendering their own set unusable.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6 | |
#7 | |
1961 crewcab
sometimes it is easier to cut the gasket on the inside... cut it all away from the pinch weld and then the whole unit can push out.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
