04-15-2015, 11:08 AM | #1 |
recommended brake fluid for my setup?
Im running a cpp firewall brake booster, Camaro front clip and ford explorer rear axle/calipers. you guys think ill be ok with DOT 3 brake fluid?
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
04-15-2015, 11:33 AM | #2 |
Re: recommended brake fluid for my setup?
Dot 3 should be fine unless you plan to autocross it and then dot 4 might be better as the boiling point is higher. For normal driving Dot should work fine.
I wouldn't suggest using dot 5 unless the truck is going to be a garage queen that sits in the garage 99% of the time and doesn't see serous driving. The main attraction to it is that it is reputed to not attack paint if it gets on it and guys with show cars use it for that reason.
04-15-2015, 08:33 PM | #3 |
So is the braking performance less with the DOT5?
04-18-2015, 09:54 AM | #4 |
Read up on high altitudes and Silicone or Dot 5 fluid
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
