Old 04-15-2015, 01:11 PM   #1
canadian_diesel1964
Pointing at 1 TDC?
Manifold is back on but distributor points at 5 or just past 1 towards the temp sender...am I missing a spot inmbetween.? 63 283 Thx!
canadian_diesel1964 is offline   Reply With Quote
Old 04-15-2015, 01:13 PM   #2
canadian_diesel1964
Re: Pointing at 1 TDC?
Sorry on uppy side down
Old 04-15-2015, 01:26 PM   #3
62 Barnfind
62 Barnfind's Avatar
You need to pull the distributer out and re stab it so it aligns with the number 1 plug wire on the cap. Looks like you are a tooth off. Once you pull it out turn it back a bit and re stab. Hard to tell from the pic. I hope this helps.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 04-15-2015, 01:30 PM   #4
canadian_diesel1964
It does help I'm just having an issue I think with the new dist gear
Old 04-15-2015, 01:34 PM   #5
62 Barnfind
You might have to turn the oil pump gear with a long screwdriver to get the proper alignment. It seems like you are in between two cylinders.
John Z
62 Barnfind
Old 04-15-2015, 01:38 PM   #6
canadian_diesel1964
I may be...I've been turning it 20 x in and out ...I have the old dist in
Old 04-15-2015, 01:40 PM   #7
canadian_diesel1964
Picture of old
Old 04-15-2015, 01:56 PM   #8
62 Barnfind
Another thing you can do is make that point your number 1 plug and set your firing order from that. Worst case you have to re set TDC and start over. I had this happened before with a different distributer.
John Z
62 Barnfind
Old 04-15-2015, 02:08 PM   #9
1963c-10
1963c-10's Avatar
Lets help with that pic.....
old on the left, new on the right
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-15-2015, 02:16 PM   #10
canadian_diesel1964
Thank you
Old 04-15-2015, 02:19 PM   #11
1963c-10
1963c-10's Avatar
No problem.
