Old 08-30-2003, 08:09 AM   #1
RShaips
Power Steering hoses ?
I have a 71 frame that I bought with power steering , I am about ready to start and drive it. I bought new stock power steering hoses but I am having a hard time determining how they are supposed to be installed. The pressure line has some crazy bends in it.A picture or a description would be helpful. Thanks
RShaips is offline   Reply With Quote
Old 08-30-2003, 10:44 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is it 2wd or 4wd I have both and could take some pic's to help you out just let me know.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-30-2003, 12:28 PM   #3
RShaips
It is 2WD ,That would be very helpful. Thanks
Old 08-31-2003, 06:26 AM   #4
RShaips
ttt
Old 08-31-2003, 10:16 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Not sure if this will help you or not
MEMBER #6377
Project "7DEUCE"
Old 08-31-2003, 10:18 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
one more
MEMBER #6377
Project "7DEUCE"
Old 08-31-2003, 01:32 PM   #7
gmtrucksaddict
p/s pump in the above pics is not stock mounted to engine block,is higher than factory, even the prop valve location is not factory,
gmtrucksaddict is offline   Reply With Quote
Old 08-31-2003, 04:41 PM   #8
RShaips
Thanks FrenchBlue but I am having a hard time seeing the power steering pump in the pictures,mine is located very low on the block,it is actually mounted to a bracket that is mounted to the motor mount. Thanks for the effort ,I appreciate it.
Old 08-31-2003, 05:13 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
My powerr steering pump is not even on the motor how can it be mounted higher than stock??? Y es I moved the prop valve.
MEMBER #6377
Project "7DEUCE"
Old 08-31-2003, 05:53 PM   #10
71elect
Steering hose pics
RShaips,
I changed over my 71gmc with a 307 V8 from manual steering to power steering a couple months back. Here are some picks of mine. Hope it helps you out!
Josh
72Chevy swb 4x4
71GMC swb 2x4
71elect is offline   Reply With Quote
Old 08-31-2003, 05:57 PM   #11
71elect
Gearbox pic's.
72Chevy swb 4x4
71GMC swb 2x4
Old 08-31-2003, 05:59 PM   #12
71elect
PS mine is a 2wd. Good luck.
Josh
72Chevy swb 4x4
71GMC swb 2x4
Old 09-01-2003, 08:09 AM   #13
RShaips
Thanks ,I think thats what I was looking for. It seems like a simple thing to do ,but I bought stock hoses and they had some strange bends , Thought I'd ask before screwing it up. Thanks for the help
