Oil pan gasket change help?
Looks like I may have some time today to change the oil pan gasket on my 67 250 6 cyl. I was looking last night at where to put the floor jack on it to make it clear the crossmember, getting it off. Could you jack it at the transmission or Bell housing? Anyone done it lately????
Thanks, Dave
Dave Benamati Hughesville, PA USA |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I think I would try a cherry picker if you have on or I use the harmonic balancer. May not be the best place but it work's..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
huh?
![]() Join Date: May 2000
I second the cherry picker idea (if it's possible). Another recommendation would be to use a felpro 1 piece pan gasket, if they're available for an I6.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Guest
Posts: n/a
Does anyone have a part # for a 1 piece oil pan gasket for 350?
Inline 69
fel-pro#1885,,,,s/block, double check though,,,jeff http://www.lsr10.com/pdf/lsrwc03p33.pdf
I got it changed but what a project it was!!!!!
I had Saturday to change it so I went to the parts store and ended up buying the Felpro 4 piece and let me tell you, I'll never do it again without the right equipment. Anyone who had the 67 250, use an engine lift and get the one piece gasket! I did jack it by the pulley (balancer) and had to jack and block and jack again to almost 5 inches to clear the cross member . Actually it was only about an inch for the x member but the oil pump was front and the rest of the distance was to clear that! To make it worse, The gasket front didn't have the front bolt holes in it because GM made that pattern obsolite. Instructions said to just not put in the 4 bolts under the pully. Guess where it is leaking now! I guess I will have to go out tomarrow and drill through the gasket and put those 4 small bolts back in. All in all, it only took me about 8 hours, a gasket and a tube of rtv heat silicone. Could be worse huh? It looks great though my back is killing me!!!
Dave
![]() Join Date: Sep 2001
This is the 1piece people were talking about for the V8. The part number for this one is FEL-OS34510T. You need the one for the I6. Check out Felpro's site, or another supplier for it:
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
