04-15-2015, 09:18 PM | #1 |
TH400 to700R4 swapdriveshaft question
Hi every body !! I have a question !!
I have a 72 C20 with a big block ,,, I am swapping the big block out for a small block. The truck has a TH400 in it now and I am putting in a 700R4. My question : If I install the small block frame mounts in the stock location will the original driveshaft from the TH400 work with the 700R4 ? Thank you in advance for any and all information !!! Have a great day ! Tom |
04-15-2015, 10:21 PM | #2 |
The Older Generation
Re: TH400 to700R4 swapdriveshaft question
I don't know about length but the front yoke is different. The TH400 is bigger in diameter than the th350/700r4. LockDoc
04-15-2015, 10:25 PM | #3 |
Length will be different and you will probably have to relocate the cross member too
1967custom |
04-15-2015, 10:48 PM | #4 |
I had to relocate the crossmember and shorten the driveshaft and the front yoke is different.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-15-2015, 11:22 PM | #5 |
Thank you for the replies !!! I was thinking wrong ,,,, I thought the th400 and the 700 were the same length and same yoke. That's why I asked here ,,, to get straightened out ! Thanks guys ! Now I know what I need to do !
Take care everybody !!! Tom |
04-16-2015, 12:11 AM | #6 |
TH700R4 uses the same slip yoke as th350. If you are going to do any towing the th400 is a much stronger transmission. I would recommend upgrading, I believe it's the sun shell. The original 's are stamped steel and prone to cracking.
04-16-2015, 12:16 AM | #7 |
Before you sell your th400 it may have some expensive factory installed parts. Namely the clutch hubs. If you know a tyranny guy it may be worth it to open it up to see what's in there. It's out of a big block 3/4 ton it most likely has the heavy duty 5 clutch hubs.
04-16-2015, 10:11 AM | #8 |
I just did this. I used the 700r4 drive shaft (you have to) and had the back half shortened. Napa supplied the conversion u-joint and I move both the trans cross member and the carrier bearing cross member forward.
Save that turbo 400..you just never know. |
04-16-2015, 10:13 AM | #9 |
The torque of a big block is HARD on a 700R4. Even built ones.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
04-16-2015, 10:49 AM | #10 |
For the 454, only one overdrive will handle that. The 4L80E .
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
04-16-2015, 10:56 AM | #11 |
Here's a few tips if you're keeping the 700R4.
The sunshell should absolutely be replaced with at the very least a GM heat treated one. Borg Warner High Energy frictions are said to be some of the best 700R4/4L60E clutches there are. Also check with a straightedge the reverse input drum where the band clamps. If there's any cupping at all, it has to be replaced. Just my experience with a 4L60E (basically the same as 700R4). Mine has been pulled 3 times and this time I did a ton of research to find out what the problems were. Works fine now!
71 K20 64 GMC mud truck |
04-16-2015, 11:29 AM | #12 |
Good advice Andy. I'm doing this as a "proof of concept" with the Dana 60/4:10 gears then pulling the whole truck apart to build it right.
04-16-2015, 11:57 AM | #13 |
A 200-4R would be a direct bolt in. Just move the cross member back and change the yolk.
Plus, it has a better gear ratio spread than the 700. And before anyone says the 200-4R is weak, I have one behind a 600 rear wheel horsepower engine and I've never had problems yet.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
