65 stepside dd build
I've had this truck for several years and finally got a notion to drag it out of the weeds and put it to use. Thanks to many of you on here I have great direction for my build. I have 3" front springs 2-1/2" spindles 5" rear springs and 2" blocks coming. Keeping it 6lug with CPP rotors from Summit. And possibly sectioning the cross member and using a power rack being I will add air bags with a York210 engine driven compressor when I settle on a permanent power plant. No need to build all the brackets and plumb everything twice IMO
Re: 65 stepside dd build
I'm in...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
Post Whore
![]() Join Date: Mar 2013
What does it have for an engine right now?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Senior Enthusiast
Welcome to the forum.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Currently has a V8 of the 60's period not sure of displacement but from what little I've had it running I may be swapping in another smallblock being it puffs some smoke pretty well.
So I've had new brake and suspension parts starting to arrive and scored a good ignition switchless tilt column from an rv still need to sort through the mess of a wiring harness and see if it will make due for time being
Posted via Mobile Device |
I decided to make my own c notch reinforcement brackets but I shall warn anyone whom wishes to do the same this can be time consuming being these frames are nowhere near a straight line in the rear axle area unlike many later model leaf sprung pickups. I made patterns for all four sides traced onto 3/16 steel plate and cut with a band saw rather than a torch or plasma to minimize grinding. It is taking nearly every c-clamp I have to squeeze and hammer them to conform to the frame contour and begin tacking to each other to maintain the desired shape. Just as I began making good headway I ran out of wire. So I will post again when I can get back at it and show some completion.
This looks familiar! LOL
Get it man! Love the stepsides!
64 LWB to SWB Step build. Daily driven! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=647168 |
So I finished up the notches utilizing all existing holes in the frame and welding in place I will use grade 8 hardware after painting to reassemble crossmember and spring pads
#13 |
#14 |
Trying out some sandblasting while I have it tore down
#15 |
#16 |
![]() Join Date: Jan 2015
coming along nicely!
* Call me NOT the website number* Justin Novick (773) 303-8251 Sales/Support Entropy Radiator / Engineered Cooling Products "The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com |
#17 |
Been a while since I've done much with the truck due to other home projects and a differential dilemma. I have a 5.3 and 4l60E awaiting in the shed and finally broke down and bought new guts for the rearend. Around here in the Midwest apparently any rearend that hasn't been in use for a good 10 years is most likely rusted beyond reliable use. Been working on crossmember mods and tank mounts for the efi ready poly tank I got from tanks inc. It's for a 49-51 Ford car. I didn't want it to hang below the frame much but wanted to keep as much capacity as I could. It's a 17 gallon unit. I cut a piece of rectangle tube to replace the rearmost crossmember and made it bolt in using one bumper mount hole the bed mount hole and another hole on bottom side of frame.I also moved the crossmember just behind axle 1" forward on pass side to help clearance for tank.
#18 |
Although much deeper in the pocketbook and labor wise I now have a rearend good for at least 100k miles.
#19 |
Along for the ride. Always good to have a dependable rear end.
#20 |
Finally got it back on rolling stock now for a heart transplant
#21 |
Lookin good. Nice job on the C notches.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
