Old 04-15-2015, 11:52 PM   #1
kyman
67 Truck ignition switch
So I have a 67 truck. The ignition switch is just layed over the column. I see that 67 was single year only for the switch. The switch in this truck has the acc position. So my question is, I need the spacer deal and the nut so I can install it correctly. What year truck do I order the parts for? Thanks again!
kyman is offline   Reply With Quote
Old 04-16-2015, 12:02 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67 Truck ignition switch
The spacer for the '67 is a one year only item and is not reproduced. You will have to find a used one. The screw on chrome bezel is reproduced and any parts vendor should have it....
LockDoc
Leon
Old 04-16-2015, 12:05 AM   #3
kyman
So it's specific to the truck? The fact that it's not a 67 switch doesn't matter right?
Old 04-16-2015, 02:04 AM   #4
swamp rat
swamp rat's Avatar
Yes its spicific to the 67, you can install an after market switch with some creative (cough) wiring
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-16-2015, 07:54 AM   #5
kyman
The wiring doesn't scare me at all, it's what I do. I just need some guidance on what switch will fit the hole. I was hoping the spacer was specific to the 67 switch, cause like I said, this one has acc so I don't think it's original. Thanks for the help!
Old 04-16-2015, 09:10 AM   #6
LockDoc
LockDoc's Avatar
The '67 spacer and screw on bezel will fit any '67-'72 ignition switch.
LockDoc
Leon
Old 04-16-2015, 09:46 AM   #7
kyman
Gotcha. I'll find a spacer and bezel. Thanks for the help
Old 04-19-2015, 05:50 PM   #8
kyman
OK so I know I'm beating a dead horse here, and I'm sure its just because I can't see what it is I'm missing. Can I buy an ignition switch, spacer and bezel for a 69 and put in the truck? Is it because of the hole in the dash or what is it that keeps it from working correctly? Thaks again guys.
Old 04-19-2015, 07:28 PM   #9
LockDoc
LockDoc's Avatar
Yes, it is because of the hole in the dash. The '67 has the small hole and the '68-'72 have the large hole.... If you enlarge the hole be sure and retain the notches and tabs around the edge of the hole to locate the correct orientation of the switch and to keep the whole assembly from turning when you turn the key...
LockDoc
Leon
